Results 1 to 8 of 8
Thread: PH swinging wildly
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    PH swinging wildly
    Seeking guidance. PH is 8 one day and the next 7
    Seems to stay within 7-8 range but the fluctuation within range varies wildly from one day to the next (especially when I put the cover on).
    I'm hesitant to add chemicals due to daily differences happening on their own.
    Thanks!
    Intex 15'x4' round AG metal frame pool, 4400 Gallon, Krystal 14" 2150GPH Sand pump/filter .75HP. Taylor 2006 test kit. San Diego, CA.
    38,301
    Re: PH swinging wildly
    That is really not possible without chemical additions.
    Post up a full set of test results.
    How are you chlorinating?
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    I use bleach 8.25%. I keep Cl level between 2-5PPM. I add about 2 or 3 cups every night. With high Sun directly on pool all day Cl seems to burn off about 2-3PPM throughout the day. Last I tested CYA was at 30 three weeks ago. I will do the full suite if tests with my Taylor kit.
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    CL 4.6
    PH 7.8
    TA 140
    CH 200
    CYA 40
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Is it high after days where there was alot of use or aeration? And did it miraculously go down again after? I can't see any way for the pH to go down without adding SOMETHING to the pool. Acid rain? LOL.
    Isolated Spa - 345 Gallons
    38,301
    And the TA is high enough that wild swings should not be possible.
    I am suspecting testing error? Something contaminating the sample or the vial?
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    Well, a few weeks back I added muriatic acid to lower PH. Having done any since, and it does swing around based on test results. If it's impossible for this to happen then I will look at other factors.
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    Haven't done any since. Acid rain. Funny.
