Thread: scummy mark around parts of hot tub just above water line
    May 2014
    London, UK
    15
    Hi all,
    About every 2 weeks I need to clean of a sort of oily scummy mark around parts of the hot tub above the water line (usually around the hidden filters) and a couple of other places....
    Is this normal - should I be doing something specific to stop this?
    Cheers
    Stuart
    First ever Hot Tub bought April 2015
    1700 ls or 450 US Gallons
    Temp 38.5c or 101f
    Bromine Generation using in.clear
    Casey's Avatar
    SW PA
    10,461
    Re: scummy mark around parts of hot tub just above water line
    Welcome!
    Is someone in it using body lotion or tanning oils? That is usually the cause of a heavy scummy line in the pool or spa. I've heard that scum balls catch all that filmy oil. Since it's a hot tub, I am unsure if you can just throw it in and it works. I know they go in the skimmers of pools... someone will have to jump in and clarify this to be sure.
    May 2014
    London, UK
    15
    That makes - sense! My daughter has excema so tends to get covered in moisturizer during a flair up - bet its that!
    Thanks for letting me know!
    Stuart
    Temp 38.5c or 101f
    wjr75's Avatar
    Jun 2013
    IL
    836
    Spa Perfect helps break that stuff down. They also have pool perfect for the same purpose.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
