My pool was built in 2007 with all Jandy equipment. It appears that the heat exchanger has a crack, as evidenced by a consistent drip seen when opening up the side panel where the drain holes are. I can't believe that we have only gotten 7 years out of this. We converted to salt in 2009. I'm assuming replacing the heat exchanger is possible, but won't necessarily be much less expensive than replacing. We have a Jandy RS Link w/ PDA and I am looking for replacement heater recommendations. One pool service company that I deal with recommends a Rheem. How does Rheem compare to others on the market and will it be compatible with my Jandy automation equipment so that I can turn the heater on/off and adjust temperatures with the PDA?
By the way - I'm not new here. I was previously registered under "smuggs" I couldn't recall my password for that account
