Thread: How soon after pouring bleach can you re-test?
    May 2014
    Millersville, MD
    46
    Just starting with the TFPC method for the first time, had to drain 50% and re-fill to get my CYA down. My chemistry was the following after the refill:
    FC: 0.6
    CC: 0.4
    PH 7.5
    TA: 70
    CH: 220
    CYA: 35
    According to the calculator (8.25% bleach), I needed to add 1 gallon to push the FC up to 5ppm. I put a gallon in, ate dinner, etc. About an hour later I re-tested, FC was the same thing.
    Am I not waiting long enough, or how long does it take before I will see results in my test?
    ~21,000 gal, IG Vinyl w/Liner, Hayward Pro-Grid DE2420 DE filter, Built: ~2002, manual vacuum, K-2006 Test Kit
    Casey's Avatar
    SW PA
    10,421
    Re: How soon after pouring bleach can you re-test?
    As soon as you add Chlorine, you can test within 15-20 minutes. If you did not hit your target FC, you need more chlorine!
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    There are a few possibilities:
    1. You could have something in your pool that consumed it or
    2. The bleach was old or
    3. Your testing was off (bad reagents maybe)
    I'm banking on #1
    Also, it's ok to keep everything under one thread. It makes it a little easier to follow your situation. You are using a K-2006 test kit, right? Was there a particular reason you are using a 25 ml sample instead of the 10 ml for the chlorine?
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    38,235
    I am not sure 15 minutes is long enough. I would circulate at least 30 minutes before testing.
    May 2014
    Millersville, MD
    46
    Quote Originally Posted by UN1017 View Post
    I'm banking on #1
    Yup, K-2006. The 10ml does multiples of 0.5ppm, while the 25ml does multiples of 0.2ppm. I knew my FC at first was going to below 1.0ppm, so testing in multiples of 0.2ppm made more sense I would think?
    Mar 2014
    Las Vegas
    288
    The 10 mL sample is more than adequate. Uses less reagent which will make your kit last a bit longer. Its all about saving money so you can afford pool toys.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
