Thread: swg effect the pump?
    Apr 2012
    chandler az
    65
    My Pentair IC40 needs cleaning, which I am waiting on a stand to clean the unit. If it fails does it prevent the pump from running.
    I have EOS automation and the lights come on the pump motor and the swg, but nothing is pumping water. I am wondering if it is a pump failure?
    I know that the SWG needs cleaning
    38,237
    Re: swg effect the pump?
    The SWG should not have anything to do with the pump running ... unless you have something in the automation for prime protection that uses the SWG flow sensor and the flow sensor is not working.
    Prime protection is something that I did not know my automation had until recently.
    Apr 2012
    chandler az
    65
    Thanks, I have a eos 3 automation system and the screen only shows device setup and orp on th screen. Waiting on the pool service company to call. For service call. Any ideas
    Apr 2012
    chandler az
    65
    what steps do I need to get the screen that has/had pool circulation, spa, blower.....etc/ do I need to reprogram what steps should I take?
