Thread: Significant scaling below water line
    Jun 2014
    Dallas, TX
    1
    Hello Everyone,
    Is there a place in the forum where guidelines are posted about dealing with scaling? I have white scales at the water line and grayish-tan scales on the walls and bottom of my pool in some significant patches.
    M. I.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Significant scaling below water line
    Welcome to TFP!
    You can start here -----> Calcium Scaling in Pool School
    There are some assumptions though...(1) you are testing your own water with one of the Recommended Test Kits and (2) you are familiar with PoolMath.
    If you post a full set of good test results, there are plenty of folks around here that can get you started down the right path.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
