My KK periodically stops moving and I suspect it is the flapper inside, if I manually give it a nudge it will stop working, but if it touches anything it stops and does not start back up again unless I manually move it with my finger. It is not crawling up walls either. There is no debris and the pressure at the pump stays between 6-8 psi, I have back washed and yet I still have this issue. Please help
