Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Help! Husband bought pool and now i ended up with maintenance duty and have no idea.
    Jun 2014
    houston, texas
    39
    Hi everybody, now im stuck with maintenance of a intex AG 18' x 48" ultra frame swimming pool (6432 gallons) with crystal clear model 635T cartridge filter. I would like to know if anyone can give me tips, advice,mentoring, ideas on how to maintain this pool clean as easy as possible for my boys ( a moody 12 yr. old, a temperamental 5 yr. old, a very active 18 month old and last but not least a 1 1/2 year old labrador, yes all males). As y'all can see i have my hands full already but here i am with my chore. I live in the beautiful hot and humid houston, texas the pool has direct sunlight all day. The pool is almost full, i added 2 cups of bleach when it was about 6 inches. I bought the borax, 10 bottles of bleach and the hth 6-way test kit (walmart). What else do i need? Can we get in immediately ( husband is desperate) or do i have to treat it and.wait some time to get in?
    Thank y'all soooo much
    Bianey
    Casey's Avatar
    SW PA
    10,444
    Re: Help! Husband bought pool and now i ended up with maintenance duty and have no id
    Welcome!
    I feel for you! All those boys! The biggest one is probably the worst as he's gotten you into this! Don't fear... we can help you!
    You need Stabilizer. Go back to WalMart tomorrow and pick some up in the pool aisle. It's called Stabilizer/Conditioner. Add it according to PoolMath.
    Also, You're going to need a good test kit! We recommend the TF100 over the K2006. You can check both of them out here Test Kit Comparison
    You will be on your way if you take some time tonight and give Dad all those boys and tell him you have Pool School! Read these to start with:
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Chlorine CYA Chart
    You will find more helpful links in Pool School.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Welcome!
    Whatever bleach you added is long gone by now, with no stabilizer in the water to protect it from the sun. I'd dump another 3 cups of plain 8.25% chlorox in and let them use it. You will need to add some stabilizer, and soon, but what else you might need depends on test results.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi there and welcome.... All pools come with maintenance, and your pool is no exception... I use cleaning and maintaining my pool as therapy... I find it relaxing... Now that test will do for now, but you want to get one of the test kits that will test for everything.... Here is a link.....http://tftestkits.net/splash-page.html
    Start reading Pool School.... There is a learning curve to owning a pool, just keep reading and re-reading it will eventually click......
    http://www.troublefreepool.com/conte...etting-started
    http://www.troublefreepool.com/conte...pool-chemistry
    http://www.troublefreepool.com/conte...rence-material
    Can you please test your water, and get us a full set of results and we can use the Pool Math to work out what your water needs.... You will need CYA also known as Stablizer... It's like a sunscreen for your chlorine.... That is essential.....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2014
    houston, texas
    39
    Thank u all for the quick respond. I will order thw other test kit that was recommended Tonight. Quick question i have read from the pool school but with the children all having scenes, tantrums and screaming i think i only retain about 1% of it all. What about the cyanuric acid do i need that as well?
    Casey's Avatar
    SW PA
    10,444
    That is the Stabilizer/Conditioner I told you to grab at WallyWorld. It's all the same!!!
    Jun 2014
    houston, texas
    39
    I just tested with the hth 6way kit cl 1ppm and br 2 what does this mean?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    You poor thing! All of those boys! What a busy life you have. BUT they will be quiet while they sleep after playing hard in the pool you are going to keep nice and clean for them.
    Good move on ordering the good test kit. I am not sure what the results mean from your 6 way kit. I am thinking CL means chlorine. That means you have 1 ppm (parts per million). That is not much with all of those boys LOL
    Chlorine=bleach
    CYA=stabilizer/balancer It is the sunscreen for your bleach.
    Good luck!
    Kim
    Jun 2014
    houston, texas
    39
    I tried twice thw test dor the cyanuric acid but the test said to add cloudy water ( which never turned cloudy) until the black dot disappeared but it never did am i doing something wrong?
    Richard320's Avatar
    Jan 2010
    19,004
    You won't have any CYA unless you add it. It's not naturally occurring.
    Until you get some CYA, target 2 or 3 on the CL (Ignore the BR, you're not using Bromine)
    The important things right now are pH and CL. Your test kit can handle those for now.
    If the pool was filled from the faucet, it's the same stuff they bathe in, so let 'em in. One day won't kill 'em or completely destroy the pool chemistry.
    Mid Missouri
    227
    All correct and good advice. I think if we put it steps it will be easy to follow. There is a pool calculator here that will help you determine the correct amounts of chemicals to add.
    Step 1- Starting now maintain your chlorine level with bleach daily. Your CYA level is 0 until you add it. Use the chart here to determine the correct chlorine level to maintain.
    Step 2- Add CYA aka conditioner / stabilizer. You can find recommended levels here. 30-40 ppm is probably what you'll want. They have it at Wal-Mart in granular form which is cheaper, you can get it in liquid form from a pool store. The liquid is more expensive but faster.
    Step 3- Start maintaining your PH level. Your kit can do that. You'll need to take the ph or red reading. Also you'll need to know the TA or total alkalinity, your kit has the stuff to measure this also. In the calculator you'll enter both of these figures to find out how much and what to add if necessary. My TA runs high because of my fill water and is always rising because of my salt water generator, so I add muratic acid about once a week to maintain my ph and slowly lower my TA. You'll just need to find out where you're at and adjust accordingly.
    Step 4- Consider upgrading your test kit. You will run out of the CYA test from your current kit pretty quick. Also the better kit can measure some things that may come in handy later.
    Step 5- I would highly recommend you consider upgrading to the Intex 2650 gph sand filter. It has a 16" tank and hold 100lbs of sand. You can buy online for under $200 delivered. It is so much better than their cartridge filter, I promise. I spent 1-1/2 summers convinced and trying to prove the cartridge filter was adequate. I wish I would have upgraded sooner, but perhaps then I wouldn't appreciate the difference so much.
    Have fun with your new pool!
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    Jun 2014
    houston, texas
    39
    Thank y'all for all the advices and tips. Quick question on the pool calculator are the set target correct or do i have to change them? I just tested after they go out and cl 1ppm and ph 7.5 ppm i didnt check total alkalinity what do i do? Do i add more bleach?
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    With regards to your goals, you need to scroll about halfway down the page until you see "suggested goal levels". Use the options "troublefreepool.com", "bleach", and "vinyl".
    CL 1ppm -> add more bleach. Add 20oz to get it to 3ppm. Also, please use plain bleach (not splashless, not outdoor, no fragrances).
    Ignore TA for the mean time, it's the last thing to worry about.
    Jun 2014
    houston, texas
    39
    OMG richard320 you are so right about the faucet water. Lol i guess that I'm too worried about the level that i didn't even think about it.
    May 2014
    584
    Forgot to mention - your pH is fine where it is.
    Jun 2014
    houston, texas
    39
    Thank you abigail K i will do that, so tomorrow i check the levels and then add what i need to add how long do i have to wait to recheck?
    May 2014
    584
    You can check levels half hour after additions; leave pump running for at least half hour after addition to mix everything.
    Yes, enter your test results into PoolMath and add the amount of bleach it indicates.
    Your bleach should have a listing of the amount of "Sodium Hypochlorite" on the label. Enter this number into the box for %bleach.
    Casey's Avatar
    SW PA
    10,444
    You can re check with in 15 minutes or to a half hour after additions. Keep your pump circulating when adding any chemicals to the water.
    Mid Missouri
    227
    Quote Originally Posted by Abigail K View Post
    Ignoring TA is not good advice. However it's not step 1 or 2. You'll need your TA value to adjust your PH correctly. The green capped bottles that came with your 6 way kit and the beaker are what you'll need for the test, instructions are with the kit. Your ph may be 7.5 today but if your TA is high and your kids splash around in the pool for a day or two it won't be 7.5 for long. It all seems complicated now, but it won't for long.
  20. Back To Top    #20
    Jun 2014
    houston, texas
    39
    How many hours do i have to keep the filter running and do i have to wash or backwash the filter at least daily?
