Thread: Wife can't wait!!!
    Jun 2014
    Clinton, NC
    2
    Wife can't wait!!!
    Hello all, First time posting and I have a new pool. I have been reading through the forums on getting things started and trying to understand the chemicals that are needed to keep my pool sparkling clean. Upon filling my pool with well water, I decided to shock it and it turned a beautiful pale green, but was still just as clear as if I had put food coloring in the water!! I took a sample of water to the local pool store to have a comprehensive test done on it and discovered that I had a high level of iron. I purchased a product from the nice gentleman and within 20 minutes my water had cleared up, major problem solved! That made me feel better but I know that my water is yet to be balanced correctly. I've been reading about the chemicals and the TFP way and feel confident that I will be able to get things right, just have to get a good test kit! One question I have is this: What chemicals should not be placed in the pool at the same time or can you actually do that all at once without fear of causing a hazmat response from the local Fire Department?
    My numbers on the test are:
    FC-.28
    TC-.38
    CC-0.1
    pH-6.7
    TA-22
    CYA-9
    I believe I've got the numbers I need from the Calculator...just wondering if any of the experts have any additional tips or advice that would be helpful. Thanks for a wonderful and enlightening website.
    18' x 4' Intex ultra frame 7600 gallon AG, 1500 gallon per hour cartridge filter.
    38,284
    Re: Wife can't wait!!!
    Welcome to TFP!!!
    How are you testing the water? Those definitely did not come from one of the Recommended Test Kits. So, I would not make any adjustments based on those numbers.
    I would guess that your CYA is too low and you need to get that to 30-50ppm and continue to maintain adequate FC using liquid chlorine.
    The water turning colors was due to metal in the water. Likely you may need to continue to use a sequestrant to prevent staining. See http://www.troublefreepool.com/conte...d-metal-stains
    Casey's Avatar
    SW PA
    10,438
    Definitely get the test kit ASAP so you can get accurate readings.
    I would add at least 5 cups of bleach a night until the test kit arrives to keep the cooties and algae at bay.
    Orlando, FL
    690
    I put borax and baking soda in my pool simultaneously and the pool water became very cloudy. You should have no reason to do this though.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2014
    Clinton, NC
    2
    The tests actually were done AT the pool store through their computer...don't know what kind of program they are using. Their recommendations did clear the water though.
