Results 1 to 8 of 8
Thread: Chlorine Test Question
    Jul 2013
    Long Island New York
    63
    Test my chlorine twice a day with the TF-100 kit religiously. In the instructions it says to use a heaping scoop of the R-0870 powder. This may be a stupid question but how much is really a "heaping" scoop. Is it me or will how much powder I use alter my test result a bit? It seems if I use a rather heavy scoop my reading tends to be higher.
    Aug 2010
    Dallas, TX
    4,052
    Re: Chlorine Test Question
    As long as there is enough there to turn the solution pink, you are good.
    When in doubt about your kit, refer to the extended test directions:
    http://www.troublefreepool.com/threa...Kit-Directions
    If you look at the FAS-DPD test, under the notes there is more detail about what I'm talking about.
    Donldson's Avatar
    NW Ohio
    2,892
    As long as there are some undissolved crystals at the bottom you used enough. Using too much doesn't affect your results, only using too little.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    38,271
    You can not use too much powder, but too little can cause problems.
    If you start with a nice deep pink with a few extra crystals, then you should be using enough. For normal FC levels, one scoop is plenty only at high FC levels might 2 scoops be needed.
    Jul 2013
    63
    Awesome, thank you. Now I feel confident my readings are accurate and my chlorine levels are where they need to be.
    jb, what FC level would you say would require 2 scoops?
    38,271
    I have no idea ... I think I have gone up to around 20ppm and still only needed 1 ... might have been a little more "heaping" than normal levels where I use a flat scoop.
    Jul 2013
    63
    ok fine, i am only around 7-12 since my CYA is high. I'm good, thank you.
    Casey's Avatar
    SW PA
    10,428
    I've only ever used 1 heaping spoon. When I dig into the powder, it falls off the spoon and I dump it into the testing tube.
