Results 1 to 7 of 7
Thread: Adding salt to non SWG metal framed pool?
    golfinglenn's Avatar
    Jul 2013
    Springfield, OR
    96
    I am curious about adding salt to my pool to soften the water a little bit. My concern is with the metal structure. It is an above ground metal framed/sided vinyl lined Doughboy. I know salt water is corrosive to metal but I am wondering if the low percentage that I want to add to the pool is enough to worry about?
    And what PPM should I shoot for?
    Glenn
    6500 gal above ground Doughboy with 200lb sand filter and solar panel heater. Converted from Baqua to BBB and never looking back!!
    Aug 2010
    Dallas, TX
    4,052
    Re: Adding salt to non SWG metal framed pool?
    You might consider borates for a pretty similar effect. The borates will help stabilize pH and tend to keep bugs away somewhat (mixed reviews) too.
    38,275
    Many people without SWG shoot for about 2000ppm, you should test first though as you are not likely zero and could already be between 500-1000ppm.
    The added salt will certainly cause corrosion faster than none, but I am not sure how much faster or if it is really a concern.
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    Quote Originally Posted by golfinglenn View Post
    Glenn
    I'm in the same boat as you. I have an in ground vinyl with metal frame and sand bottom from the 70s. I wish to add salt but afraid of corrosion issues.
    20,000 Gallons Vinyl 16x32 Inground with Stamped concrete decking. Hayward Sand Filter. DIY Diaphragm pump injection system. K-2006C Test Kit.
    450 Gallons Standalone Acrylic CALSPA 2006.
    Canadians, Get your test kit here!.
    Jul 2013
    Springfield, OR
    96
    Okay, so I bring my water up to 2000ppm in my non SWG pool. Do I need to make any other adjustments to cya, ph, alk? I see where on SWG pools they want highter cya and such, but just curious if that doesn't pertain to a lower ppm salt pool that is non SWG.
    Glenn
    38,275
    Nothing else should be changed for you. The differences are due to the SWG itself, not the presence of salt.
    Jul 2013
    Springfield, OR
    96
    Did some reading up on Borates and think I am going to go that route..........
