Results 1 to 7 of 7
Thread: Thank you!
    Apr 2014
    CA
    3
    Thank you!
    I am new to this site and I am so grateful to have found it! Within a month and a half I have taken control of my 7 year old pool for the first time! In this time I have corrected a CH of over 500 down to 250 by getting my own submersible pump and draining down to the deep end bump. The high calcium hardness ruined a brand new set of cartridges. It was an expensive lesson but ultimately it lead me to this site. FC levels are 5, a pH from greater than 8.0 down to 7.5, TA from 120 to 90, CYA from 100 down to 42, and CSI to 0.02 from who knows what! I feel that getting my own TFP test kit has made all the difference. I now know the relationship of one chemistry level to the rest and I am able to address whatever changes need to be made. The pool school, test kit, and pool math are invaluable and my pool is crystal clear and running perfectly. I am buying my chlorine and muriatic acid from the pool store because the price and concentration make it a better choice than bleach from the store and the containers are recycled. Now that I have my own test kit I have accurate results, unlike the pool store that does not take the time to test as carefully as I will.
    So this post is to send a great big THANK YOU! My pool no longer feels like a huge burden but is something that I can handle myself.
    38,521
    Re: Thank you!
    Welcome to TFP and congratulations on taking control!!!
    Sometimes the chemicals at the pool store are a better deal ... I get my acid there as well ... and there is nothing wrong with doing so if it saves us money
    Apr 2014
    CA
    3
    Re: Thank you!
    I am unable to add my pool info to my signature. Any advice?
    Re: Thank you!
    Click on "Settings" towards the top right, and then pick "Edit Signature" on the left.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Thank you!
    Quote Originally Posted by retherj View Post
    Are you going to "settings" - top right under Pool School button? Then, see/scroll down left side to "edit signature" and select?
    A post/message box should pop up for you to add info..... Hope that helps.
    Welcome to TFP
    You're done SLAMing when:
    Casey's Avatar
    SW PA
    10,457
    Re: Thank you!
    Great post! Welcome to TFP! Stick around and help others!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Thank you!
    Welcome to the forum!
    Glad things are going well for you and congratulations on taking the reigns!
    Essential Links:
