Thread: hth shock & swim
    Jul 2011
    Corinth, NY
    76
    hth shock & swim
    What is the chemical used in HTH Shock & Swim? Is it Calcium Chloride, Potassium Monopersulfate or something else?
    Donldson's Avatar
    NW Ohio
    2,892
    Re: hth shock & swim
    Calcium hypochlorite.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2011
    Corinth, NY
    76
    Is is the best one to use?
    Jan 2013
    Houston, TX
    1,079
    For what?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    38,271
    Again, member for 3 years ...
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Apr 2013
    North OKC Area
    300
    Bottles of unscented bleach is usually the best thing to use. Too much calcium causes scaling, and the other granular products have CYA which, if you get too high, will make your chlorine less effective. Use the PoolMath calculator to determine how much to add to raise FC to desired level.
    What I mean by usually is that if someone has a plaster pool and is low on CH I'd use Cal-Hypo. For any pool low on CYA, I would use granular Dichlor/Trichlor. For a pool that already has properly balanced chemicals, I would only use bleach.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
