Results 1 to 9 of 9
Thread: New above ground pool question
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Hi everyone
    We will be putting our above ground intex 18 by 48 ultra pool up on Saturday. How soon do we need to start putting the chemicals in and checking on them? Should we always keep the chlorine floater filled with the hockey pucks in also?
    Thanks
    Mike
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    38,371
    Re: New above ground pool question
    You should add chlorine immediately and maintain it from the beginning. Do you have one of the Recommended Test Kits yet?
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Hi
    I don't have the test kit yet. I figured it give me something to do while waiting for the pool to fill. I have read thru the school. My reason for asking the question is if the pool takes a day and a half to fill do I need to start adding chemical before it's full of water? Does this make sense? Also do I always want to keep the chlorine floater in the pool too?
    Thanks
    Mike
    38,371
    We usually recommend you NEVER keep a floater in the pool because exclusive use of trichlor tablets is not sustainable plan. See the last link I posted before.
    You can use them to start, but you need to keep track of your CYA level and switch to liquid when the CYA gets into range.
    I would pour a little bleach in the pool while it is filling.
    Time to start to learn to use PoolMath as well.
    Casey's Avatar
    SW PA
    10,450
    Piper Mike,
    Pool School is where it's at.
    ABC's of Pool Water Chemistry
    Chlorine CYA Chart
    Recommended Levels
    What is Trouble Free Pool Care?
    That oughta give you enough reading to get your feet wet.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Thanks. I have read thru it again and have not seen anything about the floating chloride.
    Mike
    38,371
    It is Trichlor which I know is discussed.
    Apr 2013
    Battle Creek, MI
    298
    If you have a lot of the "pucks" you're just dying to use, I suggest you save a few for when you go on vacation and give the rest to a not-so-good friend Or see if you can refund them for a few pounds of dichlor granules that will add both chlorine and CYA to begin with, then start looking for all the liquid bleach/chlorine deals you can find. And get one of the recommended test kits. Good luck.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by Piper Mike View Post
    Mike
    As best as my research suggested, the 3" tabs add 6 ppm CYA each. I am switching to TFPC method this weekend. I used tabs and bagged shock and test strips to start my pool up and ended up with CYA of 135! 36 of that was from 3" tabs. Another 27 was from bags of shock. So I would say to stay away from either and just do it right the first time. I sure wish I would have...
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
