Thread: How long to run pool pump? 13,000 gallons, hayward superpump 3/4 hp 3,450 rpm
    Just curious. 13,000 gallons, hayward superpump 3/4 hp 3,450 rpm...
    My pool place says 8-10 hours. I think that's kinda long. I'm in PA, don't get much debris, etc. I just want to know aprox how long it should run for and if it's better run run it earlier in the day or later...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: How long to run pool pump? 13,000 gallons, hayward superpump 3/4 hp 3,450 rpm
    The pool place isn't paying your electric bill. Have you read the article in Pool School?
    Quote Originally Posted by Jason B View Post
    Bump. Any idea?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    What did you think of the article Richard posted?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2016
    slidell
    58
    how about 1 hour for each 10 degrees temperature? 90 degrees then 9 hours ? or so it was said here
    Blue haven kidney style 16,000 gal gunnite including Spa, test Kit TF - 100
    Built 2000 deep end 7.5 feet, 2 steps at shallow end
    Original SWG then convert to chlorine
    Pentair Clean & Clear cartridge filter (4)
    Blue Haven Teledyne Laars Platinum II heater
