Results 1 to 11 of 11
Thread: Need 2 SWG's
    Oct 2013
    Laguna Niguel, CA
    41
    Need 2 SWG's
    I have one Aqua Rite Electronic Chlorine Generator with a Hayward T-Cell 15. My pool is 52,000 gallons and now that summer has arrived, I don't believe the unit can generate enough chlorine based upon testing. I only see one port on the genertor to T-Cell cable. Am I correct in assuming that I will not only need another T-Cell but another generator as well? Or is there a way to use one generator? Thanks.
    52k gal, Pebbleteck, Pentiar Intelliflo VS, Hayward Pro-Guard D.E. Filter, Raypack 407A Heater, AquaLink RS by Jandy, Aqua Rite Chlorinator x2, Hayward Turbo Cell x2, The Pool Cleaner robot
    Re: Need 2 SWG's
    For a very large pool you either need a single much larger SWG, or two smaller ones. The other option is to manually add chlorine during the hottest couple of weeks of the year.
    AquaRite doesn't make a SWG large enough for your pool, but some of the other brands do. Adding another AquaRite requires getting an entire new unit: control box and cell.
    Oct 2013
    Laguna Niguel, CA
    41
    Re: Need 2 SWG's
    Two Questions:
    Is there a single SWG that anyone would recommend for my needs?
    If I add another SWG identical to my existing setup, should I add another 40,000 unit and extend life of both T-Cells by setting them to generate lower? or get two 25's? etc........
    I know that another Aqua Rite & T-Cell is approximately $800-1,000 depending on sales.
    38,369
    Re: Need 2 SWG's
    Your cheapest option will be to add another Aquarite and like I said in the other thread ... get another 40k T-15 cell. Then they will not have to work as hard and you will have a little bit of extra capacity.
    Some other companies make 60k+ units, but even that would be pushing it.
    Oct 2013
    Laguna Niguel, CA
    41
    Re: Need 2 SWG's
    I installed the second SWG (Aqua Rite with T-15) and I'm running into difficulties with them. When running on a low speed of my 1 HP Pentair Whisperflo one or both SWG's will have a flashing "Check Salt and Inspect Cell" which eventually becomes a solid light. When running on the high speed, this issue does not occur. Additionally, the T-15 cell's build up with deposits very fast (1 month).
    I have read the instruction manual and it indicates that the "salt level is too low / efficiency is reduced". If the salt level is too low, why do the SWG's work perfectly on high pump speed? Is the low pump speed too slow for SWG's and causing these problems? And is the reduced effeciency is causing the SWG to work harder and build up deposits faster?
    38,369
    Re: Need 2 SWG's
    How do you have them plumbed in? Add a picture.
    The buildup is likely due to other chemistry issues. Post up a full set of test results.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    Re: Need 2 SWG's
    if they are plumbed in parrallel, that is half water from pump goes through each cell
    then there will not be enough flow for cell to operate correctly on low speed
    if they are plumbed in series, that is water from pump goes through one cell out and then into next cell your flow rate should be about the same
    with some frictional lossses
    as jbizzle said
    the build up is probably a chemistry issue
    will require a set of test results and what kit you used to get results
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Oct 2013
    Laguna Niguel, CA
    41
    Re: Need 2 SWG's
    Yes, they are plumbed side by side due to space and previous setup. I was already considering upgrading to a Pentair IntelliFlo variable speed pump. Then I could adjust to speed necessary for proper operation of both SWG's. Sometimes the SWG's work on the low speed, but most of the time they are displaying the above referenced issues. So I think I'm really close to necessary pump speed on the low setting anyways....
    Test Results:
    Salt 2890
    Ph 7.8
    FC 11
    CC 0
    TA 100
    CYA 80
    CH 800
    So CH is way too high, right? I'll test again tomorrow to double check
    Jul 2014
    Peoria, IL
    389
    Re: Need 2 SWG's
    According to where I run my SWG pool. Your salt is a little low (3200). Ph is a tad high (7.4) and yes ch is a bit high. May be partial drain and refill time.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Oct 2013
    Laguna Niguel, CA
    41
    Re: Need 2 SWG's
    aussieta's Avatar
    Jan 2014
    488
    Re: Need 2 SWG's
    yep they are in parrallel
    bit of a mission to change it to series flow
    especially with how neat you have it
