Thread: Vacuum to waste
    Apr 2013
    Alabama
    2
    Vacuum to waste
    We have an inground pool. Our filter is a Jacuzzi Sand Laser system. I need to "vacuum to waste" but waste isn't an option on my dial. The manual doesn't tell me how to do that. Do I hook it up as if I'm going to vacuum normally and set the dial to "drain"? Any help would be appreciated.
    Sue
    Athens, AL
    26k gal
    IG/heated
    Laser Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Vacuum to waste
    Welcome to TFP!
    Jacuzzi uses the term "Drain" where others use "Waste" and "Whirlpool" where others use "Recirculate". Just vacuum with your valve set to "Drain" and you'll send the dirt and water out of the system.
    Apr 2013
    Alabama
    2
    Re: Vacuum to waste
    Thank you!!
    Sue
    Athens, AL
    26k gal
    IG/heated
    Laser Sand Filter
