Thread: If I have to use tablets...
    Jul 2011
    Perrysburg, OH
    88
    For short periods of time, is it best to use Cal-Hypo tablets??? Usually just when traveling a few days every few weeks. Besides hardness (I have vinyl) what are other negative effects?
    Jan 2013
    Houston, TX
    1,079
    Re: If I have to use tablets...
    With Vinyl ... probably so.
    When in doubt do a test, see where you are and adjust fire accordingly. If you are a little low on CYA use trichlor. Cal Hypo adds CH TriChlor adds CYA. The only other negative effect is a little ribbing here if you don't premise it with a set of test results and a plan.
    ... good job understanding your pool and what the different chemicals do.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Aug 2010
    Dallas, TX
    4,052
    That is the negative effect. If CH gets too high, you risk scaling, and just about the only way to remove CH is drain and refill.
    Since you will only be gone a few days at a time, can someone at the house dump X amount of bleach in while you are gone?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Just be sure to use one or the other, not both at the same time.
    Video and Article of what happens when they are in solid form mixed together and a small amount of water is added.
    Store them well away from each other as well.
    Isolated Spa - 345 Gallons
    30,426
    Do not expect Cal Hypo tablets to perform as tri-chlor tablets do. They require a special feeder and will quickly turn to mush if not applied by using this (expensive) feeder.
    You are better off to use tri-chlor assuming your CYA is low enough you can correctly manage it.
    Jul 2011
    Perrysburg, OH
    88
    [QUOTE=duraleigh;676112]Do not expect Cal Hypo tablets to perform as tri-chlor tablets do. They require a special feeder and will quickly turn to mush if not applied by using this (expensive) feeder./QUOTE]
    Did not know that - thanks! Replaced liner last weekend and filled fresh so no CYA yet. I will add stabilizer to get to 25-30ppm then use Tri-chlor briefly as needed.
    Thanks again everyone
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
