Results 1 to 17 of 17
Thread: To SLAM or not to SLAM, that is the question.
    May 2014
    Tampa
    50
    Cool To SLAM or not to SLAM, that is the question.
    FC=5
    CC=1
    OCLT=2.5
    pH=7.6
    TA=70
    CH=325
    CYA=45
    SALT=2000
    BORATES=50
    TEMP=90
    The pool is crystal clear but with the current CC and OCLT, I am concerned something is lurking in the background and maybe I should take preemptive action. We have had a lot of rain the last week or so.
    So, SLAM or no?
    22,000 rectangular plaster. Hayward everything on a C1750 cartridge filter and a Liquidator.
    Casey's Avatar
    SW PA
    10,444
    Re: To SLAM or not to SLAM, that is the question.
    You have 1CC. I would SLAM as you lost in the OCLT.
    May 2014
    Tampa
    50
    Is it save to swim when SLAMming? I would be going up to 18ppm.
    May 2014
    Tampa
    50
    Disregard. Rookie question. I found the answer. Yes, if the water is clear.
    Jan 2013
    Houston, TX
    1,079
    Up to but not over SLAM level.
    Don't wear your good suits...
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    May 2014
    Tampa
    50
    thx
    May 2014
    Tampa
    50
    I honestly thought 24 hrs would have done it with such a low initial CC. Nope. CC=0.5 OCLT=2.5. I have 2 of 3 SLAM conditions met, but OCLT is killing me. Perhaps better results tomorrow.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Have you checked behind your lights, and brushed under and around any non-removable ladders?
    We recently had a member who was seeing OCLT=4 and she had lots of algae behind her light, literally the day after she cleaned them she passed OCLT.
    May 2014
    Tampa
    50
    Yes on brushing no on light. Just checked and OCLT=0.0 CC=0.5.
    I may pull the light anyway though.
    How can I get FC=0.0?
    Thx
    May 2014
    584
    If FC is 0, OCLT is invalid.
    If you meant FC=0 and CC=0.5 you need to get chlorine in immediately.
    If you meant "How can I get OCLT=0", I'd seriously suggest checking behind your lights.
    May 2014
    Tampa
    50
    Whoops, meant CC
    May 2014
    584
    CC=0.5, OCLT=0, water clear?
    If yes to all you fit the criteria to pass SLAM.
    May 2014
    Tampa
    50
    I understand I'm SLAM complete. Just curious how to achieve CC=0.0
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Maintain your FC at the very, very top for the Cya level for at least a week or two, and the CC will start to fade away. If you do that daily, you'll see an improvement. 0.5 is fine, but I like it when there is no pink on this test.
    It costs me some bleach, but it keeps potential problems at a bare minimum and I like that piece of mind. Overkill, but it's where I like to be.
    Essential Links:
    May 2014
    Tampa
    50
    Thx.
    May 2014
    584
    As long as all other numbers are in order, there's no real need to achieve CC=0, anything less than or equal to 0.5 is ok.
    Quote Originally Posted by chem geek
    Combined chlorine (chloramine, dichloramine, and nitrogen trichloride) primarily results from Free Chlorine (aka hypochlorous acid) oxidizing nitrogen based componds, such as urine/urea) ammonia, sweat, etc. If all you are doing is killing algae and not oxidizing the above, it's very possible you won't ever see CC show up before, during, or after the SLAM process.
    So, essentially CC=0 is hard to achieve - it is not impossible, but it isn't necessary either.
    May 2014
    Tampa
    50
    Gotcha.
