Results 1 to 8 of 8
Thread: Lubricating Pentair Multiport Valve
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I have a Pentair Meteor series sand filter that I acquired used and need to do some work on the multiport, as it's VERY hard to turn.
    I took it apart, see pics, what do I need to lube? The spider gasket seems decent enough and the previous owner wasn't having problems with it, so I'd like to leave that this season. Do I just lube that, plus the center pin, or is there more that needs lube.. spring? What about that teflon washer that's cupped?
    Thanks!
    Ps. I plan on cleaning all that icky dirt out.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    30,431
    Re: Lubricating Pentair Multiport Valve
    If you enjoy messing with and fixing things, google that up to see if they make a "re-fit" kit. It looks like that multi-port has been through a lot and I would suggest replacing anything that moves (and the spider gasket)......they all look quite worn out.
    By far, the best way to get your pool up and running (without leaks) quickly is a new multi-port. That would be my first choice.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Yes, I'm very mechanical.
    Thanks for the suggestion.
    I have looked into it a bit, I'd still like to try lubing and reassembling it though, as I have nothing to lose but a little time if it doesn't work.
    Other than some rust and some scale from the minerals in the water here, it's really not that bad once I cleaned it up. Still have to de-rust the spring.
    The spider gasket is plenty supple and not flattened out. It's just yellow and ugly because of the previous owner's acidic pucks. :what:
    What points should be lubed on these? I know the spider should be, how much, thin, or generous coating? I see there's a black o-ring on the shaft that has lube on it, that's the only place that does.
    I know about the pin, how about the spring ends, or the metal washer?
    I'll see if I can find a replacement Teflon washer, but the question is, do they start out new as flat, or curved?
    Thanks
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Definitely need to lube the o-ring. Could put a thin coat of lube on the main shaft and the bore it rides in. Spider gasket doesn't need lube but a thin coat wouldn't hurt anything.
    The washer is Polyethylene, not Teflon. It would have been flat to start, but repeated single side rubbing by the handle induced the curvature.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    You can get the scale and calcium off the plastic by soaking in a 1:5 mixture of Muriatic Acid/water. Soak the parts, they might need a little scrubbing, wear gloves and goggles.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Sweeeeet! Good info. Thanks!!
    Which o-ring, the big thin one on the Multiport cover?
    I got this to use for lubricant, since the forum recommends a synthetic non-petroleum silicone or teflon ptfe lube.
    Super Lube Synthetic Grease With Syncolon "PTFE"
    I made a paste out of Barkeeper's Friend and coated the parts in it. The oxcyllic acid in it (derived from rhubarb) eats calcium and rust. HEHE
    If it needs more cleaning, then I'll soak it in MA. Thanks for the tip, I was wondering if I could do that, but was afraid of hurting the plastics.
    EDIT: Forgot url link to lubricant.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Yes, lubricate all o-rings. The lubricant you found should work fine.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    What a little cleaning will do.
    All oxalic acid, didn't even need the ma.
    Hard to see in the pic, but the spring is shiny new.
    Got it all lubed, cleaned, and reassembled. Moves VERY nicely now. Can't wait to rid myself of this Intex cartridge filter. HAHA
    Will test as soon as I get some pea gravel to use under my sand bed.
    Please remind me again what size pea gravel?
    Thx everyone!!
