Thread: Baffled by Circulation Pumd
    Jun 2014
    Barefoot Bay, Fl.
    2
    Have a 2004 Vita Spa L7000C series tub, with a Waterway TM 0061N22C3 circulation pump. If I set the pump to run only 12 hrs. a day, or shut it off for any reason it won't start back up on its own and of course I get a flo error. This happens even if I just test it and turn it right back on. I like to mess with thing even if I don't know what I'm doing. So I took the cover off the back end of the pump motor and using a flat bit screw drive, turned the armature a little and then turned it on again and it works. I just can't figure out why it would start after I turn the armature but not after it has been running even when I turn it right back on. It had me so mystified I tried it a dozen time at least. And each time it would'nt start, but everytime I turned the armature it did start. And the armature turns very easy. If anyone knows why I would be grateful, I am sure I probably need a new pump, but maybe something else is wrong also. Machines and women have outsmarted me for years. Thanks
    Re: Baffled by Circulation Pumd
    Welcome to TFP!
    That is a fairly common failure, very likely the start capacitor.
    Jun 2014
    Barefoot Bay, Fl.
    2
    Thank you. I forgot to add that I tried several times, leaving the power on and turning the armature and never got it to start. I guess I better order a pump, Thanks again.
