Thread: How to set the Jets in pool
    May 2014
    New Caney, Texas 77357
    5
    I have a 13,000 gallon gunite pool. How would you suggest I set my four jets to get the best water circulation.
    Re: How to set the Jets in pool
    Welcome to TFP!
    There are many ways to do it, depending on many details of your pool. Here are some hints. Aim at least one return down towards the bottom of the deep end. Adjust things so that the water moves in a consistent circular pattern that carries debris to the skimmer(s). Watch surface debris to see how you are doing.
    tucsontico's Avatar
    Mar 2014
    202
    I am not an expert but from my limited experience you want to adjust the return jets to create either a clockwise or counter-clockwise flow throughout your pool. You'll have to experiment to see which works best. The objective is to get the water moving around your pool and back towards the skimmer. You may have to tweak the eyeball returns several times to get a decent flow. You also may have to consider which way the prevailing winds come over you pool, etc. Good luck!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    Butterfly's Avatar
    South Carolina
    10,045
    .......and, you can toss in a ping pong ball to test the motion
    You're done SLAMing when:
