Thread: Purchased the SWG
    May 2014
    Westport, MA
    28
    Purchased the SWG
    So I decided to take the plunge... I purchased the Hayward Aqua Rite Pro SWG.
    One question is in regard to the pump I have, which is the Hayward EcoStar, and that is should I wire the SWG to be running anytime the pump is running (even on low rpm)? Will this offer enough flow to enable the flow switch?
    Thanks
    18X36 inground with vinyl liner.. Hayward DE .... Upgraded to Hayward Ecostar
    26,700 gallons....
    Aug 2010
    Dallas, TX
    4,052
    Re: Purchased the SWG
    I'm going to answer "maybe". My SWG works fine on low speed.
    My recommendation would be to run it all the time the pump is running and adjust output to maintain your FC properly. I shoot for about 5-6 FC as I've found this ensures I never drop too low, even when there is bather load.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Post removed: I just realized you have a VS pump, and my post was relevant only to 2 speed pumps.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Look in the manual for a minimum flow rate, although that only really helps if you have an accurate flow meter, although it week give you a better idea of what it needs.
    I have a flow meter, FlowViz, and keep my slow speed above the minimum rate for the SWG.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Wire it to run whenever the pump is running. You don't really need a flow meter. Just set the pump, and if the SWG doesn't have enough flow increase the speed until it has enough flow. That's the beauty of VS pumps.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
