Results 1 to 10 of 10
Thread: Skimmers working but something seems amiss
    Jul 2013
    Clarksburg, MD
    93
    So skimmers work, suction is really good when I turn down/off main drain, but pool surface is still full of stuff. Weir doors stay open and don't seem to close or lift even a little. They move freely as I can push them up and there is no restriction. Also I know the suction works great as it almost ate my hand off when feeling for suction. When I crank rpm up to 3000 flow improves but still debris tends to float by. Water is midway, maybe slightly higher up the door and if I hold the door close skimmer drains very quickly.
    Any ideas?
    18k gallon IG Sunstone Pearl pebble finish pool, Jandy Aquapure 1400 SWG, Jandy 1.5HP VS E-Pump, Jandy 60sqft DE filter, Jandy Legacy Propane Heater, Polaris 3900 Robotic Cleaner, TF-100 w/ SpeedStir, Anchor Mesh pool cover
    38,274
    Re: Skimmers working but something seems amiss
    Does the weir float up when the pump is off to prevent stuff from floating out? If so, they are fine.
    I would be embarrassed to show a picture of my pool right now. It is COVERED in flower droppings from the palm trees and has been for a week. Constant cleaning of the skimmer is not helping it seems
    The skimmer can only do so much and if the wind is blowing away from the skimmer, it will not catch much.
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by Omnipotent View Post
    Any ideas?
    like jblizzle said, if the winds are blowing away from the skimmer, it is useless. You say "skimmers" so do you have more than one? if so, can you turn them off independently of each other? I have 2, one on each end of our oval pool, each plumbed with its own ball valve and depending on whether the wind is out of north or south, I turn one of them off and keep the one going that has the wind in its favor. My pool is always clean. thank goodness I opted for the second skimmer....
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    There's supposed to be some kind of float at the top of the weir door, usually a piece of foam I think. Eventually it rots & falls apart, then the door behaves as you describe. Something to check...
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Jul 2013
    Clarksburg, MD
    93
    I do have 2 skimmers and can turn them off independtly. To your point the wind has been from the NW and blowing everything to the deep end, so I will try that.
    Also will test to see if the skimmers are off in the weir door raises into place, I'm just used to watching them bob back an forth creating a Venturi of sorts to suck more water in with each opening/closing.
    Thanks
    38,274
    The skimmer that I have now does not really "bob" as much as I remember at my previous house. It must have been for buoyant. As long as it is not laying flat, it is forcing the water to draw from the surface which is what it is supposed to do.
    I imagine you could add some foam to the back of the door to make it float more, but would have to be careful it does not float too much and let air be pulled in.
    Jul 2013
    Clarksburg, MD
    93
    So just closed shallow skimmer and door closed like it should. Will keep shallow skimmer off and see if deep end skimmer will work better. Also opened mains as well (had them off trying to force more suction through skimmer).
    Also, my returns are just 1" PVC with no directional adjustment. Is it possible to add directional adjustment to these returns? PB looked at me like I had 2 heads when I asked if they were putting directional fittings on the returns.
    Thanks again.
    38,274
    There are no eyeballs in the returns? That is odd for a new pool. Usually they are 1.5" female threaded fittings in the pool that allow you to screw a jet into it.
    Jul 2013
    Clarksburg, MD
    93
    Yeah these appear to be 1in straight PVC, definitely no threads. Only threaded fitting is for the Polaris cleaner. Anything to retrofit these to accept an eyeball.
    38,274
    Wow, that is strange ... not impressed with that pool builder.
