Thread: electronic timers?
    May 2013
    Fort Lauderdale, FL
    423
    electronic timers?
    I'm interested in upgrading my twin intermatic mechanical timers (pump and vacuum booster) to something electronic and easy to program. Worth it? Any recommend models?
    I have an old school pool heater without an operating thermostat, so right now to use it, as a safeguard I pull the "off" stops off the timer. It would be nice to just hit a button instead.
    Edit, I see intermatic makes replacment electronic models... PB 300 series?
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Re: electronic timers?
    If everything works, I wouldn't upgrade. There is nothing wrong with upgrading, I just like to have a stronger reason before messing with something that is working.
    If you do upgrade, I like the Intermatic P1353ME.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Jason, As an engineer I know that nothing works so well that I am not willing to try to break (oops I mean fix ) it. I think this is also part of the guy code.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
