Results 1 to 17 of 17
Thread: broken pool :(
    Jun 2013
    Southeastern British Columbia
    79
    broken pool :(
    hey all, I have been posting for quite a while as we were going to be building an intex above gorund with a full wooden deck, and we are about to "break ground" this weekend on that project, but decided to take a quick detour to look at a property that is on the market here (court ordered sale) that has a pool!
    the house is in really good condition considering, but there is a cracked pipe to the pool. There is a finished concrete deck all around it, its quite large not sure of size but Im thinking 20x40.
    My question is, is this pool going to be salvageable? I know it will likely need a new liner, not a big deal, but do you think the concrete will have to be jackhammered up to repair the cracked pipe??
    thanks for the help
    pool people are so helpful!!
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: broken pool :(
    i would think: yes, it would have to be jackhammered up and repaired. This may not be as expensive as you think though depending on how much concrete must be jack hammered and replaced. If you know right where the leak is, the area would be relatively small.
    if the price is right, it may be worth it, sounds like a nice pool. Certainly a big one that someone shelled out quite a bit of cash for.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    38,271
    Re: broken pool :(
    With no pictures or details about the actual problems ... impossible for use to estimate what it may cost to fix.
    How do they know there is a cracked pipe or where it is?
    Jun 2013
    79
    Re: broken pool :(
    true Jbizzle...
    The agent only told us there is a crack in the pipe, nothing more. As a court ordered sale they don't really say much... sigh
    I will try and have a closer look at the pool on our second walk thru. It was really rushed, she said there was another family coming to view and really rushed us. Not that impressed with the realtor to be honest...
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: broken pool :(
    When you're there next time, fire up the pool pump and equipment if the water is at a safe level. Heck, even turn it on for a bit if it isn't. See if the pump works, maybe see if there is circulation, leaks... Let it run the whole time you're there and then look at it after. Can probably learn a decent amount in a visit if they let you and they should. It's part or the house and a potentially expensive part if it needs lots of work.
    Isolated Spa - 345 Gallons
    Jun 2013
    79
    Re: broken pool :(
    Good advice! I will inquire about that!
    jjwalker's Avatar
    S. Louisiana
    198
    Re: broken pool :(
    whatever the problem, it certainly wouldn't stop me from buying the house. anything is fixable...but like stated above, w/o exact details it would be hard to know if you're going to get sideways on the deal.
    and also like stated above...how do they what the problem is? realtors will have no vested interest in it after you close
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: broken pool :(
    If you get more serious about the ourchase, could you take a pool inspector with you to check things out?
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: broken pool :(
    Quote Originally Posted by jjwalker View Post
    wouldnt stop me either... but I would want to know what repairs are needed, that way I know how much to negotiate off the price...
    Jun 2014
    Portland, Me
    64
    Re: broken pool :(
    This is more about real estate, but distressed properties go quickly if they are priced properly. If you are serious, put a clause in that releases you pending failed inspection. IG pools are mighty expensive to build these days! 20x 40 is big! Pics and Wouldn't besi skeptical the broker. If it is a good property, it will go!
    Jun 2013
    79
    Re: broken pool :(
    we are planning to put together offer on the house right away!! If you have experience with court ordered sales, by all means please share
    We are meeting with a realtor experienced with these types of sales, and a mortgage broker today!!
    We are prepared to buy it for asking price (750,000) but we realize that it is a long shot at this point, but gonna throw in whatever we can at it!!
    Wish us luck!!!! This is beyond our wildest dream home!
    Jun 2013
    79
    Re: broken pool :(
    so there is the pool, the wood siding building you see in the picture is the pool house~
    it has a MASSIVE wood fired boiler for heater. I cant believe how big it is!! It is like the size of a car!
    There is a section of earth (not concrete decking) from the far end of the pool to the pool house and the realtor says that is where they think the cracked pipe is... not sure of how she knows that, not taking her word for it.
    I don't think in this situation we can do much, other than pray it is an easy fix, as we can not get a pool inspector out, there is NO ONE in our town that even does pool maintence or builds... nearest one is 3 hours away!! And we need to move FAST on this deal
    Re: broken pool :(
    Good luck
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: broken pool :(
    You shouldn't have shown this property to me, I may just have to put an offer in on it too! It's gorgeous.
    As far as the pool goes, how bad can it be? I realize that's a loaded comment, but geez, look around. I'd be willing to drop a few pennies on pool reno in relation to the total outlay.
    I wish you the best of luck.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2013
    79
    Re: broken pool :(
    Are you in BC??
    Jun 2013
    79
    Re: broken pool :(
    Never mind. It's a terrible place! It's all delapitated and run down. And it smells. LOL
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: broken pool :(
    No, Maryland, but I can move.
