Thread: High pH causing a rash?
    Feb 2008
    Milford, CT
    My son has recently come down with a rash that we cant seem to explain. Its not itchy (he rarely scratches it), and it doesnt seem to bother him......he is as happy as normal.
    We've tried several different "changes" to see if it helps, but the rash remains. Changed detergents and re-washed clothes, no help. Recently cleaned our carpets, so Ive rinsed them thoroughly with water, no help. Washed down all furniture, etc he normally touches with soap and water and then just change.
    For the heck of it, I took the pH of the water that was coming out of the carpet when I rinsed it. 6.9/7.0.........doesnt seem too bad. Also for the heck of it, I took the pH of our hot water (aka what he takes a bath in)....7.6.
    Im wondering.........could the high pH be causing a rash? ive never tested my heated water before, so I really dont know if this is a recent development or not.
    Thanks in advance.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Mar 2007
    San Rafael, CA USA
    Re: High pH causing a rash?
    My tap water is close to 8.0 in pH and having tap water that is from 7.5 to 8.0 is normal as this reduces corrosion in pipes. So I don't think that's a new occurrence.
