Thread: Solar Blanket - Water surface not completely covered?
    Jun 2014
    Berwyn, PA
    13
    Hi,
    I just moved into a house with a pool and when putting the solar cover on noticed it was cut to shape with bubble side up. The pool is not symmetrical so I cannot just turn it over. I can flip it over but a portion of the pool will no longer be covered (7'x1' of a 35' x 18' (approx.)) along the edge. Is it better to have the complete water surface covered bubble side up, or majority covered with bubble side down? Or should I try to get small strips to cover up the spots?
    Thanks in advance.
    Casey's Avatar
    SW PA
    10,453
    Re: Solar Blanket - Water surface not completely covered?
    Welcome. I would flip it bubble side down, trim the excess and put it on the open spot. The previous owner cut it wrong if it's bubble side up.
