Results 1 to 9 of 9
Thread: Changing a DPST to SPST Timer
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    My Timex timer broke recently (plastic shaft inside snapped) and no longer will spin. I bought an Intermatic T101M as a replacement. Beside the fact that mechI got a super deal on it on eBay, but didn't realize that it was a SPST as opposed to the DPST that the Timex is. Which means that the terminal strip is different. On the DPST, there are 4 terminals, 1-4, with a black and white set coming from the breaker box and a black and white set going to the pool pump. The new timer only has 3 terminals, the A post and 1 and 2. How exactly should this be wired? Anybody else have this problem?
    10 year old 18x32 inground, vinyl liner 1 year old, 25,000 gallon Grecian, Hayward ST244 Sand Filter, 1hp Hayward pump, Diving board, Side Steps, Koolcrete decking located in middle [s:37hekvij]earth[/s:37hekvij] Georgia.
    Re: Changing a DPST to SPST Timer
    You need to get a different timer if you need a DPST switch. The T101 only switches a single line. You need a T104 if you want to switch two lines.
    Jun 2012
    western NY
    1,559
    Is your pump a 240 volt or 120 volt unit? I am inclined to think 240.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    The pump is 110. I just changed it out this spring. It's a Hayward 1.5 super pump. In fact, I don't have any 220 lines in my breaker box.
    When using 115 volts, there is almost never a reason to use a DPST switch. Do you know what was being switched on each pole of the old switch?
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    Quote Originally Posted by JasonLion View Post
    No, there's just the 4 insulated wires coming in to the timer box, 2 white and 2 black (plus 2 grounds). The only thing on the circuit is the pool pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Pointyhead View Post
    Sounds to me that they were switching the neutral for some reason?? Without being there with a meter it's hard to tell.
    Support the site
    Jun 2012
    western NY
    1,559
    Looks like the Neutrals connect to the A terminal, line to terminal 1 and load to terminal 2
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    Quote Originally Posted by danpik View Post
    That's what I'm thinking. The clock motor is pre-wired to A (neutral) and hot to Terminal 1.
