Results 1 to 10 of 10
Thread: Heavy rains
    Heavy rains
    Water level now above skimmer opening do I just wait for it to evaporate or pump some out?
    Looking for opinions,Thanks.
    24` AG 15,000 gals
    Hayward CC1500 150 sq ft. cartridge filter 120 gpm
    1 hp single speed motor connected to Hayward mod # SP15921 LFP pump.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: Heavy rains
    It won't hurt anything but until the water is in the skimmer the skimmer isn't effective at cleaning debris off the water surface. How far above is it? Evaporation could take a while.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Heavy rains
    I would pump some out and let it skim.
    You're done SLAMing when:
    duckhunter27's Avatar
    Jul 2013
    Dannebrog, Nebraska
    59
    Re: Heavy rains
    I always take advantage of a heavy rain and Vacuum to waste. The vacuum works so much better that way and I get rid of the xtra water.
    24ft x 52in Round AGP Heritage pool Aquamaster 19 in sand filter & 1 hp pump. Clear Solar blanket 12 Mil. TF-100 Test Kit. Pool filled June 3rd 2013 well water.
    Jul 2012
    Seymour, In
    49
    Re: Heavy rains
    As the others stated, drain it down so the skimmer can be effective again.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Heavy rains
    Quote Originally Posted by duckhunter27 View Post
    +1. And by vacuuming to waste, you won't have to clean your filter as soon after vacuuming. I have a sand filter, so I take the opportunity of too much water after a rain to backwash my filter thoroughly. Might as well get some good use out of having to dump water...
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Casey's Avatar
    SW PA
    10,435
    Re: Heavy rains
    I've drained my pool off 3 times this year.
    Re: Heavy rains
    Thanks for all the info,we seem to be getting more rain than usual this year.
    24` AG 15,000 gals
    Casey's Avatar
    SW PA
    10,435
    Re: Heavy rains
    I remember last year being pretty wet too!
    May 2014
    NJ
    12
    Re: Heavy rains
    Perfect time to backwash if needed
    13,000 gal 21' x 54'' Signature RTL pool, Hayward Power-Flo LX 1.5hp, Hayward S180T Filter, CL110 Chlorinator
