Thread: 1 in 10,000 dilution for testing bleach %
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    For the 1 in 10,000 dilution to test bleach %, a 2-step serial dilution of 1 in 100 is indicated (i.e. a 1 in 100 followed by another 1 in 100).
    I've noticed that the recommendation is add 10ml TO 1 litre water to achieve the 1 in 100 dilution.
    Doesn't that result in a final volume of 1010ml and therefore a 1 in 101 dilution, rather than a 1 in 100 dilution?
    Am I being pedantic?
    Jan 2013
    Houston, TX
    1,079
    Re: 1 in 10,000 dilution for testing bleach %
    Quote Originally Posted by Abigail K View Post
    Ummm. Yes.
    In all seriousness - point well taken. A 1% margin of error is close enough for the types of calculations we do. Most of us are off by more than 1% regarding pool volume.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    To be technically correct you want 990 ml of water, rather than 1000 ml, to add the 10 to. However it is considered impractical to measure 990 ml as distinct from 1000 ml, so the instructions were simplified. In any case, there are much larger sources of error later in the process. This one is not worth worrying about.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    I guess you could measure 1000 ml, then take 10ml out
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
