Results 1 to 11 of 11
Thread: Review New Pool Design?
    Jun 2014
    Austin, TX
    17
    I'd like your opinions on the design of a pool I am considering. Let me know the things I should be on the look out for. PB wants $90K. The pool includes a spa elevated 6 feet (to patio level - my house sits on a 6 foot foundation). Spa drains into pool down rock wall. From patio level, there is a double stairway, separated by a grotto, that leads to the pool and deck, 6 feet down. Yard has a further elevation change of 3-4 feet (so requires footers and elevated pool wall in back). Bedrock is 6 inches under the soil. The top of the grotto is flooded with bubblers so you can sit on top of it. Deck and coping is Oklahoma flagstone.
    Here is a 3-D video fly-through of the design:
    http://youtu.be/p2JD5SxE0MA
    34' x 16' (19035 Gallons Estimated)
    Perimeter 96.5 Linear Feet
    Area 564 Sq.Ft.
    Depth 4ft. x 5.5ft. x 4ft.
    Spa raised 6 feet with zero-edge spillover
    Grotto (sit on top, water fall, and bench underneath)
    1 Bench Total 15 Sq. Ft, 2 tanning shelves Total 56 Sq. Ft
    Salt Water
    Steel 8" o.c. - rebar, 8" o.c. both ways
    Steel in beam 1/2" rebar x 4
    Plumbing and Equipment:
    Pool Pipes - 2" schedule 40 pvc
    Skimmers: 2 independently plumbed for optimum control
    Returns: 8 looped for even pressure
    No Main Drain
    Pump � Variable Speed Hayward and Water Feature Pump
    Cleaner �Hayward Shark Vac
    1 Auto Fill Valve
    Install Vacuum Breaker(s) at Hose Bib(s)
    (4) Bubblers
    Deck and Masonry:
    Coping � Oklahoma Flagstone Oklahoma Flagstone Peach Buff or Taupe
    New Pool deck 730 Sq Ft. in OK Peach
    Turndown as needed rubbed concrete
    172 Sq. Ft. Stone Steps
    Univ Color Logic LED (Network) Light in pool and 1 Univ Color Logic LED (Network) Light in Spa
    PS8 Controller
    Plaster: Sunstone Pearl Color: St. Croix
    Thanks for any insights you can provide.
    May 2014
    Lewisville, TX
    29
    Re: Review New Pool Design?
    Welcome! I really like the design. From the looks of living with three women, 90K is cheap . Also that duck will cause a mess so I would get rid of him . Honestly, not sure about that price. It is quite expensive but with that drop I am not surprised.
    Jun 2014
    Austin, TX
    17
    Quote Originally Posted by Jase1125 View Post
    Yeah, by my calcs, the drop is costing me around $25K, with the elevated spa, lots of stairs, all the planters and of course the grotto, which actually is a brilliant piece of design synergy since you'd have to build stairs there anyway.
    Go for it!! I love the elevation changes in the design.
    Aug 2010
    Dallas, TX
    4,052
    I am worried about you using Oklahoma stone with salt water. Lots of reports of that being a problem here in Texas. Don't get me wrong, you'd have to take my salt system from me by prying it from my cold, dead hands, but I don't have any stone.
    I don't see a heater for your spa?
    Jun 2014
    Austin, TX
    17
    Here are some updated specs from the PB. Now we are $96K...
    Pool:
    35'9" x 16'8" (19,609 Gallons Estimated)
    Perimeter 96’10” Linear Feet, Area 581 Sq.Ft.
    1 Bench Total 15 Sq. Ft, 2 Beaches Total 56 Sq. Ft
    Excavation and forming
    Excavate and form pool shell
    Shell walls to be 8" ‐ 10” thick with 12” bond beam
    Rock excavation – no extra charge
    Steel & Gunite
    Steel 8” o.c. ‐ rebar – 8” o.c. both ways
    Steel in beam 1/2” rebar x 4
    California style ‐ upgraded gunite with fiber mesh
    Pool Pipes – 2” schedule 40 pvc
    No Main Drain
    Pump – Variable Speed Hayward and Water Feature Pump (SP3400VSP)
    Cleaner –Hayward Shark Vac with Cart (RC9742)
    1 Auto Fill Valve (Pool Miser PMI‐MP101)
    (4) Bubblers ( 3 on the Grotto ledge, 1 on Entry Beach) Bubbler and spill over pump (Hayward SP2315)
    Spa
    7'10"’Horseshoe shaped with Hayward 400k BTU Heater (H400fd)
    6 Jets Massage Waterway Pulzar jets ( 2106170 or 2106510 )
    2 flush mounted floor jets for foot massage.
    6 ft. Spillover
    Blower‐ Air Slencer (ASF‐1636120f), Hayward Pump (SP‐3010X15AZ)
    Deck and Masonry
    Coping – Oklahoma Flagstone Oklahoma Flagstone Hickory
    New Pool deck 730 Sq Ft. in Oklahoma Flagstone Oklahoma Flagstone Hickory
    172 Sq. Ft. Stone Steps ( includes Tread and raisers )
    Run pipes from down spouts for
    Tile
    Standard tile for pool icluded
    Brown tile ‐ CDS IRI CAR and CDS IRI CAR 6 upgrade add $210.24 Deco tile is the only upgrade
    Blue Tiles ‐ CDS STAR SIE and MAS DS 650 upgrade add $911.52 Both Tiles are an upgrade.
    Sanitizing
    Hayward Salt system ( T‐9)
    Hayward Sence and Dispence system ( AQL‐CEM3‐120 ), (AQL‐CHEM)
    Filter‐ Hayward Cartridge (C4030)
    Electric
    Connect all equipment to panel box and run one electrical outlet to lower deck
    Univ Color Logic LED (Network) pool light & 1 Univ Color Logic LED (Network) spa light (LS‐CUN11150
    PS8 Controller ( AQL‐PS8 ), Aqua pod Remote (AQL2‐POD) Aqua Connect (AQ‐CO)
    Install door alarm(s) leading to the pool yard
    CLI Sunstone Pearl Color: St. Croix
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Just a few thoughts...
    Your filter is "properly" oversized. Why not also go up to the T-15 salt cell? Fairly small upgrade price and it will run at a much lower percentage extending the life significantly or so it is believed.
    One pool light will not be very bright on many of the colors with your dimensions.
    All the goodies in your project sound fun!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2013
    Phoenix, AZ
    130
    Love your design. With your elevation change, have you thought of doing an infinity pool?
    Add another $30k for the catch basin if you go infinity
    Jun 2014
    Austin, TX
    17
    Quote Originally Posted by vudoo222 View Post
    Thanks for the suggestion of an infinity edge. Yes, the elevation makes it doable, but I have decided against it because 1) I would't be able to get the infinity "look" from inside the house because the pool is 6 feet lower than the house, 2) the view from the pool itself is of a bunch of trees that are fairly nearby, 3) I am getting an infinity effect from the hot tub and 4) cost.
    PB said $6-8K minimum.
    Jun 2014
    The Woodlands, TX
    167
    With that much elevation drop, that price seems pretty reasonable.
    I am taking the gamble on salt water with stone. I did, however, buy some super duty 3M sealant specifically made for stone in salt water pools. It's about $150 / gallon but it works well so far....
    8,000 gallon in-ground gunnite geometric. Wet Edge Satin Matrix. Triple overflow water feature.
    Hayward - TCell 15 SWG; TriStar VS Main Pump; SwimClear 425 Cartridge Filter; ProLogic 4 Automation, SuperII Water Feature Pump; Polaris 280 w/ Booster
    Link to my Build
