Thread: FLO Error
    Jun 2014
    Maryland
    2
    FLO Error
    I currently own a Sundance Optima hottub (probably 2005) and noticed a FLO error. I did replace the flow switch and replaced the filter to no avail. I also tried running it without the filter in it and left it powered down for 30 mins as well. All pumps seem to work when I push the buttons to turn them on. My father (who knows way more about electricity than I) ran a voltmeter on the heater and that appears to be okay, however, the tub is not producing heat. I am curious what the piece circled in red in my picture is. It connects from the fliter to the heater an I am thinking this may have went up. Any input is greatly appreciated.
    Knoxville, TN
    41
    Re: FLO Error
    That is the circulation pump which pumps water through the heater and will close the flow switch if working properly.
    Sounds like your pump had pumped its last days.
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
    Jun 2014
    Maryland
    2
    Re: FLO Error
    Quote Originally Posted by CPSScott View Post
    Thanks SOOO much. I guess I am confused. The little pump circled in red is the circulation pump, but what is that bigger pump right behind it? That's where I got confused because that pump seems to work fine.
    Knoxville, TN
    41
    Re: FLO Error
    That would be the jet pump for the therapy jets. It works independently of the circulation system.
    APSP CST Certified
    CPO Certified
