Thread: Passed SLAM ... Still Chewing Chlorine!
    May 2014
    Las Vegas NV
    45
    Hello,
    I've passed the SLAM procedures 2x and on a typical day I'll use 3 units of chlorine. The past few days in Vegas have been extremely windy and I've been going through 6 units a day. There is a lot of construction in the area and I've been removing plenty of leaves, dirt and junk from the pool daily. Is using that much chlorine on a windy, dirty day normal? Does construction have anything to do with it? Also, how close together can you add chlorine and muriatic acid.
    Thanks in advance!
    9700 gallon outdoor in-ground 11x26' plaster pool; Pentair Intelliflo Variable Speed pump; Pentair Clean and Clear Plus cartridge filter;
    Pentair MasterTemp 400 natural gas heater; 2-wheel "The Pool Cleaner"
    Dec 2010
    San Diego, CA
    1,137
    Re: Passed SLAM ... Still Chewing Chlorine!
    So with all that dust and leaves and junk you have your explanation: those are dirtying your pool and causing the increase in CL consumption. Most people say 30-60 mins apart. I sometimes put them in at the same time but opposite ends of the pool.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    May 2014
    Las Vegas NV
    45
    Thanks for finally giving me my answer! The whole spring was the same way, very bad this year, and I thought there was something else wrong. The one good thing about it happening was it led me to this site.
    Dec 2010
    San Diego, CA
    1,137
    Well then that's not all that bad lol. Welcome to the site
