Results 1 to 10 of 10
Thread: Floating Weirs?
    May 2014
    MILLSTONE TOWNSHIP, NJ
    87
    Floating Weirs?
    Having problems with old damaged Hayward skimmer weir doors...A pool repair guy said to put in a floating weir/basket into the existing skimmer basket area and forget the doors! Anyone familiar with this set up and whether it works?
    33,000 gals, DE, IG, plaster, Purex Triton FNSP 60 filter, Pentair Super Flo 2hp, Pentair MinMax Heater
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Floating Weirs?
    Yeap, that is how mine is set up.
    Works fine. It's a two piece setup, the basket and the weir, the weir fits into the basket. Make sure your skimmer basket is deep enough.
    Floating Weir: http://www.sunplay.com/Pentair-Skimm...80-038-000.htm
    Basket: http://www.sunplay.com/Pentair-Skimm...80-037-000.htm
    No connection to the store. Just a quick google search to show pictures.
    May 2014
    87
    Re: Floating Weirs?
    Sorry to be a pain, but when the doors are working properly it creates a "current" of water that sucks everything into the skimmer from the surface; with just a basket in there (and no doors) there is no such "current" and everything just stays in the pool....am I missing something? Would this product magically create the current I am describing by itself?
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Floating Weirs?
    The floating Weir creates an accelerated current, just like a Door Weir, by drawing a current of water over a slightly elevated edge. It keeps the crape from floating back into the pool because the Weir is higher than the basket, and gets a little higher when the pump shuts off.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Apr 2011
    Murrieta, CA
    2,360
    Re: Floating Weirs?
    Hello,
    I can't compare, when I got my pool it came with the floating weir. It does the job, I have a 2 speed pump and it runs 90% on low, and it works. The floating weir part creates the "surface current", and the basket catches the floating debris. It's pretty efficient.
    You'll need to check the opening size to make sure the basket fits. The solid part is the floating weir it rides in the basket. The part numbers cross reference to the part that was specified in the other post. Look at the bottom of the web page that the links are on.
    The depth of the skimmer need to be deeper than 7 3/4" and the opening across where the basket sits, should be round and larger than 7 1/2" and smaller than 8 7/16".
    Depending on the amount of debris you get in your pool (leaves/twings) will determine how often you'll need to empty the basket.
    Hope that helps. I you have any other questions don't hesitate to ask.
    Apr 2011
    Murrieta, CA
    2,360
    Re: Floating Weirs?
    Also depending if where the weir door attaches isn't broke you might be able to get a replacement weir door.
    http://www.inyopools.com/pool_parts_oem_weirs.aspx
    May 2014
    87
    Re: Floating Weirs?
    Quote Originally Posted by bobodaclown View Post
    Hello,
    I ultimately found out that my skimmer is a Pentair S20 Admiral with the weir doors attached to permanently mounted pins in the side walls. There is no way to properly put a replacement weir door into that design (my saga is on a separate thread and I am going to post this there as well to help others); however the A&S pool guy who gave me the skimmer info from my 1999 records, said try to put the door in backwards and although not perfect it will work for the most part. Did that (duh!!) and it worked! Unfortunately, someone knocked off one of the permanent mounting pins on the other skimmer so am going to try this circular weir design in that skimmer. I will then see which works best and go from there...whew!!
    Apr 2011
    Murrieta, CA
    2,360
    Re: Floating Weirs?
    In the owners manual http://www.pentairpool.com/pdfs/AdmiralS20OM.pdf page 3
    They do make a weir/basket that fits:
    16 85001200 Floating weir, basket
    18 85000100 Basket
    Actually it looks the the links I posted earlier are the exact ones.
    You'll want both pieces the basket and the weir.
    Feb 2008
    Los Gatos, CA
    128
    Re: Floating Weirs?
    Which one worked better in the end?
    Oct 2007
    Parkland, FL
    752
    Re: Floating Weirs?
    Mine Weir was broken when I bought my old house 11 years ago. I got a weir with spring loaded pins on each side and it was still working when we sold the house this month.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
