Thread: Kids playing with returns
    buddywiser's Avatar
    Morgantown, WV
    Some kids came over and pointed the return in the deep end up and then covered the one in the shallow end with their hands to make a fountain. Can this do any harm to the lines or am I paranoid?
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    Baton Rouge, LA
    Re: Kids playing with returns
    I think you're paranoid.
    If you're lines can't handle the full pressure of the pump at any given time, you might as well know it now. If its not leaking now... you can sleep good tonight. There will be other things to worry about by tomorrow.
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    Jul 2007
    Suwanee, GA
    Just wait until they figure out they can put a noodle against the return and squirt the water anywhere they want, including outside the pool.
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
