Thread: BBB Method
    Mar 2010
    Spring, TX
    1,082
    BBB Method
    Did I miss something or what, but why are we no longer using the BBB method?
    I got it from this post
    Congratulations on your up coming pool ... but, please do not buy chemicals before you need them. This is why we no longer use the BBB term. Odds are you will never need to use the borax or the baking soda. So, you may end up just having to use them in your laundry and refrigerator.
    You can certainly buy stabilizer (fill water has none) and bleach though.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: BBB Method
    BBB stands for Bleach, Baking Soda, Borax. Many of us (including me) never use any of them.
    • Bleach is to raise FC
    • Baking soda is to raise TA
    • Borax is to raise pH
    With my SWG:
    • I never add bleach
    • TA is fine and never needs to be raised
    • pH constantly rises and borax is never needed
    Why call this method by a name derived from chemicals that many never need.
    I think it should be called the "Do your own testing, understand the effects of adding chemicals, understand the CYA/FC relationship, always maintain proper FC, don't add stuff you don't understand, don't trust pool store advice, don't trust pool store testing" method, but it doesn't really have a ring to it.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Re: BBB Method
    Same metod, new name. TFPC - Trouble Free Pool Care.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: BBB Method
    Only the name changed from the BBB method to TFPC method. It changed because many people never need to add baking soda or borax, yet many new people were stockpiling quantities of both or dumping them in blindly thinking they were some magic pill that would instantly clear a swamp and make the pool maintenance-free.
    Mar 2010
    Spring, TX
    1,082
    Re: BBB Method
    Ok thanks for clearing it up. I thought you would never have to use Borax or Baking Soda again. I use Baking Soda every now and then to raise my TA when it gets too low.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: BBB Method
    The thing is many people are always fighting rising TA and rising pH so never or almost never have need for the Baking Soda or the Borax, and as Richard said the newbies would go out and stock up on bleach, borax and baking soda before ever testing their pool water and learning its trends.
