Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Change to Salt or no??
    May 2014
    Westport, MA
    28
    I am interested in changing from chlorine to salt.... good idea or not??
    Just got pool chemistry perfect with the chlorine, but if I can switch to salt I will.
    Which SWG is best for me....
    Aquarite, or intelliflo....
    Thanks
    18X36 inground with vinyl liner.. Hayward DE .... Upgraded to Hayward Ecostar
    26,700 gallons....
    Re: Change to Salt or no??
    You can switch to a SWG if you want. Members of this forum are about evenly divided between using SWGs and not.
    AquaRite is a good brand. I don't recommend getting an IntelliChlor unless you also have a Pentair automations system. Without the automation system the user interface is very limited compared to other brands.
    May 2013
    Fort Lauderdale, FL
    423
    Salt is still a chlorine pool. The only thing that changes is the salt in the water allows the generator to create chlorine for you instead of adding bleach. Unless you have stone for a pool deck, I'd go for it. I did last year and I'm super happy having nearly automatic chlorine intead of buying bleach. I went pool pilot nano+, installed it myself and I'm very happy with the results. Get a cell that has the twice the capacity of your pool so it only runs at 50% instead of 100% duty cycle- so for you a 50-60k cell.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jul 2012
    Southeastern IL
    21
    If you are looking for convenience a SWG is a good solution, if you think it will be cheaper to operate you may be disappointed as the initial cost of the system and occasional cell replacement will make it a wash at best in my experience. I switched to a SWG five years ago and have been happy since, however I travel regularly and my pool is not maintained while I’m away, I have been gone for as long as 12 days and returned to a perfectly clear pool that only required minor adjustments.
    18x36 IG Vinyl, ~25K, TF-100, Jandy 1HP 2 Speed Pump, Jandy AquaPure 1400 SWG,
    Hayward DE 3600 Filter, Pentair MasterTemp 200 NG Heater, DIY Install in 1990
    Aug 2010
    Dallas, TX
    4,052
    I couldn't keep my pool clear without SWG. I travel too much to do any daily maintenance.
    Dec 2010
    San Diego, CA
    1,137
    I travel a lot too but for me I couldn't justify the cost of an swg due to replacement costs of the cells. So I went with a stenner CL dosing pump solution instead.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    May 2014
    Westport, MA
    28
    Thanks for the prompt replies..... I am thinking of the Aqua Rite Pro... prices vary greatly....
    One ???? is there a down time for the pool in switching? Meaning my pool chemistry is perfect right now, and if I add 600 lbs of salt, and install the SWG will I loose the chemistry in the water?
    Thanks again
    26,700 gallons....
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    There should be no reason to "loose" (sic) your chemistry.
    You can add salt up to manufacture recommendation at any time. This will not affect anything else.
    When you are ready to turn on the SWG, add CYA to bump up to 60 -70.
    That's it. Of course this all assumes that you are maintaining FC properly and keeping pH in range in the mean time. Don't let algae get a toehold and then try to fix it with the SWG.
    I noticed that when comparing cost of SWG vs chlorine, no one seems to consider the value of their time into the equation. I personally feel that the time I would spend lugging bleach bottles around plus daily FC additions tips the balance waaay in favor of the SWG.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by carlscan26 View Post
    You should see how much chlorine I was buying and carrying home to maintain FC in a 44,000 gallon pool in Texas. It was simply too much effort. I thought a Liquidator would help maintain FC when I'm gone, but it was only good for about 4 days. And, still, there's all that carrying of bottles...
    Jun 2013
    South Florida
    118
    Just installed a SWG a few weeks ago and I'm a fan so far. Got tired of having to stop home after work to pick up more bleach. It's not going to save any money in the long run, but it seems a lot easier from a daily maintenance stand point.
    Oct 2011
    Minnesota
    164
    The other item to think about is possible corrosion issues. Some people have issues and some do not.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    May 2014
    Westport, MA
    28
    I had a concern about the corrosion aspect, but I was told a sacrificial zinc anode would be sufficient.... Not sure how or where to put that though....lol
    26,700 gallons....
    Oct 2011
    Minnesota
    164
    If you go that route, do a search on here about the sacrificial anode (and what material is best). They are easy to install and not too much $.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by zimm View Post
    Salt is still a chlorine pool. The only thing that changes is the salt in the water allows the generator to create chlorine for you instead of adding bleach. Unless you have stone for a pool deck, I'd go for it. ......
    Zimm
    Why is a stone decking area an issue?
    Thanks
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Aug 2010
    Dallas, TX
    4,052
    It may or may not be an issue. There's been lots of discussion of it here. Seems in Texas, we have more likelihood of etching of the stone. I don't know if you will have the same issue there in NY or not. But, here in Texas, some have it, some don't. I don't have stone around my pool so I can't give you any experience comments.
    Dec 2010
    San Diego, CA
    1,137
    Quote Originally Posted by RobbieH View Post
    This is of course highly situational: my pool is about 1/3 the size of yours and our amounts and intensity of sun light are different. I need 3 quarts a day to maintain my pool's FC in the summer and less than 1/4 of a qrt (1 cup) per day in winter. So for me the SWG didn't cost justify.
    Jun 2014
    Long Island, NY
    340
    RobbieH
    Thanks for the reply
    All of my pool coping is something called Westchester stone, which are pretty good size stones, and we just put in a large Paver patio butting up to that, to play safe it sounds like i should not go the Salt route
    May 2014
    Westport, MA
    28
    Is there a chart or standard to tell how much salt to add initially..... I ordered my SWG today, and should have it by Monday....
    Is it wise to add the salt now, or wait until I have the equipment and install it?
    26,700 gallons....
    Apr 2014
    Stony Brook, NY
    159
    Pavers are fine with salt...not sure about that "stone" coping you have though.
  20. Back To Top    #20
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Check out PoolMath. Good for determining all your chemical additions, including salt.
    Also check out Water Balance for SWGs.
    You can add salt at any time. It doesn't affect other chemicals and adds a nice silky water feel.
    By the way I used to live in RI (Newport and Portsmouth), and dated a girl in Tiverton.
