I am ordering the inrush limiters from Digikey as I think this will also fix my problem.
When you look in the box it has as an AS32, not an SL32, the only difference appears to be the width of the prongs - for anyone that has used the SL32 did you have any issues? Did you just spread the prongs to fit the 17mm width? Do you reuse the limiter spacers with the new part?
Thanks
Clint
