Thread: Can I use these tabs?
    JenMichelle's Avatar
    Apr 2014
    St. Louis
    65
    Aqua Chem 3 inch chlorinating tabs, it says trichlor under ingredients. I DO NOT use tabs at all anymore since I found this site, but I have just drained most of my pool due to metal staining and my cya is a bit low. The old owners of the house left these tabs and I used them at first until I switched to liquid chlorine only. Can I temporarily use these to raise my cya a bit? Does anyone know if these contain any copper? I am just scared to use them because if they do I will have to start all over! I was told by someone that might just be where all of the staining came from in the first place.
    I would buy new ones at pool store but they are out of the smallest container and I don't want to buy a lot.
    24' x 52" AG / Hayward Sand Filter
    Hayward Power-Flo 2 Speed Pump
    TF100 test kit / Pool Rover Hybrid Robot
    St. Louis, MO *GO CARDINALS*
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Can I use these tabs?
    If they do not contain copper, they should be okay for use.
    You're done SLAMing when:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Yep...those are OK to use. According to this link (http://www.lowes.com/pd_86397-1772-0...ductId=1102709), they do not contain any metals.
    Jun 2013
    East TN
    309
    I have some Aqua Chem 3" tablets and they are just trichlor and nothing else. Walmart sells them also.
    Just for informational purposes, there are two different kinds of Aqua Chem powdered Dichlor shock at Walmart. They are orange boxes and bags. One has copper and the other does not. I think the one that has the copper says Clear Blue or something. This is unrelated to your tablets but just in case you have those and are going to use those to raise your CYA.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
