Results 1 to 7 of 7
Thread: Aerator to increase pH
    Exclamation Aerator to increase pH
    I've read more than once on here that some posters have made an aerator they use to increase the pool pH. Does anyone have any pictures or plans on how to make one? I'm looking for something in 120v.
    -38,000 gallon pool and 1600 gallon spa
    -Triton II TR140 sand filter
    -In ground
    38,475
    Re: Aerator to increase pH
    Most just hook up to the return jet and spray the water in the air ... No power required.
    Or you could run an air compressor into the water, or run a waterfall, or spa. Anything that gets water exposed to air.
    You have a spa, why not run that?
    Jun 2013
    East TN
    309
    I dont know if inground pool returns are made the same as above ground returns. If so you could make this and point it upwards to where is shoots the return water up out of the water. It will aerate that way.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Mar 2007
    San Rafael, CA USA
    12,082
    You generally get more aeration forcing a water flow into the surface of the water to create many tiny bubbles. See this post, this thread, this thread, and this thread.
    Jun 2013
    East TN
    309
    Quote Originally Posted by chem geek View Post
    Yea I knew it was probably not the most efficient way to aerate, but it works fairly well and figured I would throw an option out there.
    Thanks for the suggestions, guys.
    How long will it take for the pH to go up? Assuming it's a 38k gallon pool, 7.0pH, 120 TA, 5.0FC. I come in at 5am and pool's gotta open at 9am. Will running it this log have effective pH increase?
    -In ground
    Mar 2007
    San Rafael, CA USA
    12,082
    With decent aeration, you should see it move from at least 7.0 to 7.2 in that 4 hour timeframe, but it may take more like a day to get it up to 7.5 or higher. The outgassing is faster at low pH and higher TA as shown in this table that shows the degree of over-carbonation of pool water at various TA and pH levels.
