Thread: SLAM or not?
    RenegadeT's Avatar
    Apr 2013
    GSO, NC
    28
    SLAM or not?
    I think I've been true to the TFP method, haven't added anything but salt, cya, and elbow grease brushing the walls, been using my TF100 to check the FC regularly. I've still been having issues with what looks like rust on the light blue/white liner, but upon closer inspection (dive underwater and look with goggles), it looks more like green algae in a few spots. The spots it pops up are along the edges in the deep end where flat bottom meets angled walls, the hard parts to get with either the wall brush or pole vac.
    I am always passing the OCLT, water always looks crystal clear, CC is always 0 - 0.5.
    I have to admit, I perform my CYA test at night, indoors, under fluorescent light, and I am still "getting the hang of it". I do get consistent results though, was 60, but recently down to 50 after i manually added 3" right before massive rains brought the water level up 3" to the overflow
    Any thoughts on algae popping up in very localized places...circulation issue? This is our first year with solar cover, and it seems to occur more when the cover is left on for a few days without removing.
    and of course tonights test results...
    FC 3.5
    CC 0.5
    pH 7.5
    TA 60
    CH 25
    CYA 50
    I shut the SWG off, will check OCL, because the FC looks really low. FC was 6.5 4 days ago, and I thought I had the SWG set at a decent maintain level.
    TF100 kit, 26k Gallon 18x36 Vinyl inground by Blue Haven Pool, TurboCell T-15 SWG, SmartPure ozonator,
    Hayward SmartFilter cartridge with 1.5hp dual spd. Hayward SmartMax Star Pump.
    38,305
    Re: SLAM or not?
    I prefer to do the OCLT closer to shock level FC. I would boost the FC up with bleach and do the OCLT. Although if you see algae, then you need to SLAM.
    May 2014
    Lewisberry, PA
    93
    Re: SLAM or not?
    Hi Renegade! Seems like you have a handle on the whole TFP system. Strange how that one spot keeps "popping" up algae spots on you. The only thing I could suggest is to somehow find a way to brush those spots good and SLAM the pool so they don't come back. You gotta treat tuff algae tuffer!!
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    RenegadeT's Avatar
    Apr 2013
    GSO, NC
    28
    Re: SLAM or not?
    Strange... FC 4.5, CC 0.
    This may have been the first time I actually measured 0 CC, usually there is at least a slight pink tint after adding the 5 drops of reagent.
    Casey's Avatar
    SW PA
    10,448
    Re: SLAM or not?
    Take your cover off and let the pool breathe daily and give it a good brushing! The only time I would recommend covering the pool and letting it covered is for vacation.
    Mar 2014
    Las Vegas
    288
    Re: SLAM or not?
    Quote Originally Posted by RenegadeT View Post
    With the way you are doing your CYA test, I would say your CYA is much higher than what you are measuring and you may not have been maintaining enough chlorine. Test it again in daylight with the sun to your back.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
