Thread: Dosatron
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    Dosatron
    Has anyone used a DOSATRON to inject their bleach?
    http://www.dosatronusa.com/products/...09-11-GPM.aspx
    I use them at work on several applications to apply certain chemicals to water prior to adding to a tank.
    You would install it inline and the pumped water powers the doser and then takes a gulp of the bleach and adds it to the flow. Very easy to adjust. Designed for chemicals. Very Precise. Reliable. BUT....Pricey...$$$
    Anyone use these?
    Southern Ohio, 18'x36', 8'x3' deep, Vinyl, Hayward 1hp Super Pump, Hayward Sand Filter, Hayward AquaRite 25k SWG, 5-3'x8' Solar Panels, Hayward AquaSolar, Aqua Pro 137k Heat Pump
    Taylor K-2006, Taylor K-1766, Taylor SpeedStir, hth 6-Way with OTO
    Re: Dosatron
    It seems far from ideal for pool use. They are designed to inject consistent concentrations of a chemical regardless of flow rate, while what you want for a pool is consistent amounts of a chemical regardless of flow rate. To put that more simply, one of these will add less chlorine as the filter gets dirtier. It also looks like it will need a bypass, and has a number of other minor disadvantages for pool use.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Dosatron
    Have you looked at a Stenner Peristaltic Pump..... ?
    http://www.uswatersystems.com/system...ner-pumps.html
    This is the cheapest place to buy them I've found... And they're on sale at the moment....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    22,544
    Re: Dosatron
    Even the smallest unit at the lowest setting (.02gpm) is 1.2 gph and if you ran your pump 8 hours a day that would be about 9gpd. Even at 1 hour run time it'd be too much bleach.
    You'd either have to dilute the bleach a lot or you'd have to plumb it where you could take it out of the circuit after a short length of time.
    Having said all that. I have looked at the Chemilizer and like the fact that it doesn't require electricity. I just couldn't justify it.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
