Thread: wet edge satin matrix pool vs spa question - texture
    May 2014
    Houston, TX USA
    23
    We're moving into the plaster stage of construction of our new pool next, and we will also have a spa. We've signed up for Satin Matrix from Wet Edge for the whole thing. We're pretty sure we will like the texture of the Satin Matrix for the pool.
    My question is this - should we try to get a smoother texture surface for the spa? My wife said she read that people with pebble finish spas were regretful because it hurt to sit in them after a while.
    Any experience on this? I have no idea whether my builder will even entertain the idea of using different surfaces for the pool and the spa, but I want to make sure I get it right
    Thanks!
    13K gal, IG Wet Edge, Aquapure salt system, variable speed pump, July 2014 completion, spillover spa, Zodiac MX8 cleaner, Jandy Lxi nat gas heater, iaqualink
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: wet edge satin matrix pool vs spa question - texture
    Welcome to TFP
    Some folks do apply tile to the seats or a different finish to the spa alltogether so it isn't as rough on skin and swim suits. No reason you shouldn't consider it as an option.
    Essential Links:
    Nov 2013
    Los Altos, CA
    30
    We decided on the Primera Stone instead of the Satin Matrix for both the pool and spa for that reason. Can't say it would be uncomfortable for sure with the Satin Matrix, but for the cost delta we decided it wasn't worth the risk. Good luck with your decision.
    Free Form IG Pool with overflow connected Spa. 28K gal. Finished Sept. 2013.
    Wet Edge Primera Stone (Tahoe Coast)
    Intelliflo VS Pump. Paramount Cleaning System. IntelliClor IC40 SWG. Sta-Rite System 3 Cartridge Filter.
