Split by moderator from HERE. Please start a new thread for your questions so you can get personalized responses and avoid confusion in another member's thread. Thanks, jblizzle
What is "slamming?" I'm a newbie and have the same color algae problem. Chemical levels are all look normal. The vacuum is picking everything up so no major debris. My filter is normally at 11 psi and it was at 15 so I backwashed. Still no major changes. Any help?
That is quite a bit of improvement. Hang in there and keep slamming. I thought I had all the leaves out of mine until it cleared up enough to see the bottom and I still had a small pile in the center of the pool. You may find something similar in your case as the pool clears. You are doing a great job!
