I was hoping to get a salt water chlorine generator and install it this spring until I started reading this forum. Then I decided to go with a stenner chlorine dosing system for several reasons:
-costs less than than a swcg ( no salt cell to replacein 3-5 years)
-dont need to add salt and therefore one less parameter to test for
-has the ability to raise chlorine levels at a faster rate than swcg if desired
I was able to obtain a free storage tank ( brine tank from an old water softener) here is a photo of some of the parts I used:
-Omon H5lA timer...$40 used off ebay has two seperate programs (1 for pump and one fore chlorinator) and keeps time in case of power failure
-AC current switch $35 ebay ... prevents the stenner from injecting chlorine unless filter pump is running
-DPST relay $14 ebay; because the omron timer relay is single pole. I wanted to switch both "hot" leads to turn on the filter pump
- leviton $19 lowes 10,20,30,60min timer switch this switch is wired to manually overide the timer should I want an extra dose of hypo
-2X2x1/2 pvc tee $2 lowes... to splice into my return line injection point here are some photos of the project:
* one mistake I made was due to my haste in buying the relay off ebay. I didnt realize that the coil was 110v dc... so I had to make a quick run to Radio Shack to purchase a $3 bridge rectifier Everything is installed and working well so far
