Thread: Hayward diverter valve position
    Jun 2014
    Conroe, TX
    3
    Good day, all,
    What an incredible, resource-filled site this is! I have fired my pool cleaning company (once I found that my chemicals were way out of tolerance) and begun to do this myself. I have taken a marginally clean to a fabulously sparkling pool with the advice contained within. Now, on to more advanced actions. I am about to undertake the cleaning of the four filter cartridges in the Hayward C4025 filter. My question relates to the position of the PSV valves from the main drain and skimmers feeding the pump. In any of the three positions there is no way to close off the valve to prevent water from backing up into the pipes once I shut down the system and release the pressure. Is that even a concern? Will I need to re-prime the system? Or will I rely on the pump to pull the water back into the system (with the relief valve open on the filter assembly)?
    Lance
    18K gal, IG gunite, Hayward Northstar 1.5HP, Hayward C4025 cartridge filter, Goldline AquaRite SWG, attached spa
    38,524
    Re: Hayward diverter valve position
    Welcome to TFP!!!
    If the pump is above the water level, then the water will not "back-up" and out of the pipes. The pump will be able to pull the water back up and prime itself. And yes you would leave the air valve open on the top of the filter until water shoots out.
    Jun 2014
    Conroe, TX
    3
    Thank you very much, Jason. I will give it a go as such.
    Lance
    Jun 2014
    Conroe, TX
    3
    Piece of cake. Just gets intimidating until you do it. Note the difference from the old filters to the new filters. The other reason I canned my pool company.filter replacement.jpg
    Lance
    38,524
    Good work
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Wow, beautiful pool!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
