Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Help me with my swamp!
    charcharkitty's Avatar
    Jun 2014
    Stilwell, ks
    10
    Hello, I am in need of some help with my above ground pool. My fiancé and I bought a foreclosure home with an above ground swamp. There was a tarp that barely covered the top. When we took it off, it looked like there is about 2 years’ worth of leaves at the bottom. We have done our very best to clean out as much leaves as possible, without being able to see the bottom of the pool. It seems to be a never ending process. I bought a leaf eater to help. We have replaced the filter and have had the pump running with no problems for a few weeks. I bought a Taylor k2006 testing kit. My results as of today at 4:00pm are …
    FC 0
    CC 0
    PH 8.0
    TA 60
    CYA 50
    I need your help with what step I should take next. I think I am close to slamming it but I believe I need to get my PH down first? To do this PoolMath is telling me to add 90oz of backing soda and 9.9oz of muriatic acid. Does this sound correct? I am open to any advice. I am very new to the pool world and any help would be greatly appreciated. I have read pool school over and over and ordered my kit. I’m ready to do this!!
    16,200 Gallons
    AG
    vinyl
    sand
    38,524
    Re: Help me with my swamp!
    Welcome to TFP!!!
    You are off to a good start
    You are right you need to follow the ShockLevelAndMAINTAIN Process and first you should lower the pH. There is no need to adjust the TA at this point. Just set it in the NOW column and forget about the target.
    You should order refills for the CYA (R-0013) and FAS-DPD (R-0870 and R-0871) tests NOW, because you will certainly run out before you finish the SLAM.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,023
    Exactly what jblizzle said. Get more regents before you start. If you run out before your pool is clean, it wil not be a good situation at all.
    Your CYA of 50 is ok for maintenance. What I am going ot mention is not required, but may help the process time line.
    If your water is not very expensive, you might consider drainig half the pool and refill. It will remove half the junk that needs cleaned to start with. It will also cut your CYA to 25 and save a lot on the amount of bleach required to get you in good shape.
    If you dont want to or cant drain half and refill, thats ok. It will just take longer and will use quite a bit more chlorine to fix you up.
    The baking soda is for TA. You wont need to fool with that until much later after the slam.
    Divin Dave,
    May 2014
    SW, MO
    58
    That's going to be a great pool when it's all cleaned up. I know it's hard but keep skimming that bottom and get as much out as you can each day. Every little bit will make the slam go that much faster.
    Jun 2014
    Stilwell, ks
    10
    Thanks guys! Im still working on getting my ph down. Its still at 8. The last 2 nights I have added 18oz of muriatic acid and haven't seen a change at all. Am I doing somethimg wrong or should I keep adding more acid?
    38,524
    Are you using PoolMath? With a volume set to 12800 gallons and the pH NOW at 8 and the TARGET at 7.2 with the TA NOW at 60 ... it says you need 68 oz of 31% muriatic acid. No idea where you got only 18 oz.
    So, go put about 1/2 gallon in the pool, circulate for 30 minutes and retest. If you need to adjust more, use PoolMath to calculate how much to use.
    Once that is set, get to SLAMing!!!! No need to wait a day between all the adjustments.
    Jun 2014
    Stilwell, ks
    10
    I was having a hard time getting my PH down using poolmath so I decided to measure my pool again. Turns out I was off by 4,000 gallons! A little embarrassing to say. Now that I figured that out, my ph is in balance. I finally started to SLAM last night. I've been checking my FC and CC every hour. My target FC is 16 but I still haven't hit it yet. My last test results are...
    FC 7
    CC 1.5
    PH 7.4
    TA 60
    CYA 40
    30,432
    That FC of 16 is not some "hope for" goal but rather a hard number that you need to get to....now.
    You are not SLAMing your pool until you make the decision to put enough chlorine to get to that target and then hold it there. Use Pool math and it will tell you how much you need.
    I am going to sound very abrupt but I will bet you you will be unable to maintain your FC of 16. You are being tentative instead of following the very precise directions on how to SLAM a pool found in pool school. Here they are again....http://www.troublefreepool.com/conte...tain-shockingl
    Once you make the commitment to follow these directions, you will get your pool clear. If you play pattycake with the algae, you will have a green summer.
    Jun 2014
    Stilwell, ks
    10
    Well shoot, I though I was being tentative by checking every hour and using poolmath. Im not sure what else I can do but read the SLAM article again and try to find where I am making errors. My last results were
    FC 13.5
    CC 1.5
    CYA 40
    PH 7.4
    Thanks for the help guys. Im really trying my hardest. I'll put up some update pictures soon.
    38,524
    Add more FC and test in an 30+ minutes. Repeat as needed.
    Jun 2014
    Stilwell, ks
    10
    Finally hit 16!!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,657
    You can do it! You are on the right track with the good test kit!
    Now get that FC up to 16 and do your best to keep it there. That is the only thing that is going to eat all of the green.
    It can be done and you are on your way!
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,023
    Hi Charkitty,
    you arent making errors. What's happeing is that the FC is being killed while fighting the algae. WIth as much algae as is in your pool, that is happening very very very quickly. Thats why your fC measurements are lower. than you expect. You have to hit it and hit it hard and strong and often with chlorine and dont let up!! As time goes on and the more algae that gets killed off, it will be easier to keep the FC at SLAM. The first couple of days are tough.
    Quote Originally Posted by charcharkitty View Post
    FC 13.5
    CC 1.5
    CYA 40
    PH 7.4
    Divin Dave,
    Casey's Avatar
    SW PA
    10,461
    Keep SLAM'ing the pool. MAINTAIN. MAINTAIN. MAINTAIN.
    Jun 2014
    Stilwell, ks
    10
    Here's an update picture. Still struggling to keep up FC. but still checking every hour/ half hour. Last test results ...
    FC 15
    CC 2
    This was taken this morning. 24 hrs into SLAM
    16,200 Gallons
    AG
    vinyl
    sand
    38,524
    That is a good bit of improvement for 24 hours. Looks like most everything is almost dead and then it will be a filtration job.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    You're doing it! Just keep testing and adding! Up to 16, up to 16, up to 16!
    You'll start to see it hold better soon and you won't have as much trouble maintaining that SLAM level.
    Love to see the progress pics!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jul 2011
    phoenix
    133
    Big improvement for a first day. Please keep the pics coming. It helps others in your shoes hope and proof that it can be done
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Jun 2014
    Stilwell, ks
    10
    Hey all! I'm still seeing big improvements and loosing less FC everyday. I'm trying to upload update pictures but it keeps failing? Anyways, I had to add someone water after backwashing and vacuuming. My CYA is super low -40. Should I add stabilizer during the SLAM?
    16,200 Gallons
    AG
    vinyl
    sand
  20. Back To Top    #20
    38,524
    Your CYA can not be negative if that is what you are saying 40ppm is fine for the SLAM
    To raise your picture storage allotment, you either need to Become a TFP Supporter or follow the How To Post Pictures tutorial.
