Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Switching from cartridge filter to sand filter
    Jun 2014
    Douglasville GA
    10
    Hello,
    I've got a few issues so far this summer. I'm fairly new as in just started last year in attempts to take care of this pool. It's been a challenge as large trees are way too close to the pool but that's another story.
    First, my cartridge filter was left outside during our winter and has to be replaced as a piece broke off and it's not filtering properly. It's actually about 6yrs old too. My pool is only 18 ft round approximately 8,000 gallons water
    I want to upgrade to a Hayward sand filter. I've been calling around to several pool stores and online.. I get different answers with each call which only adds to my confusion. One store says that I have to get a 21" Hayward sand filter because I have a Hayward 1.5 hp pump and if I go with a smaller filter the large hp pump will blow the laterals right off. First, I hate to admit that I'm not sure what the lateral is! I admitted this and the saleswoman said a lateral was like fingers that move or filter the sand. The next pool store says that I can purchase a 16" Hayward sand filter without any problem but can't go any smaller due to the pump size.
    Another question I have after my phone calls to pool stores: which sand is best? Zeo sand or the other? The salesperson said that you can use 50 lbs less sand if you go with Zeo sand. Is this true?
    Fortunately, I remember this website from last year and I feel confident that I will receive the most appropriate answer here.
    If you could recommend any specific attachments that I might require in going from a cartridge to a sand filter I would appreciate it. I also require a new test kit too.
    Thank you!
    38,271
    Re: Switching from cartridge filter to sand filter
    Welcome to TFP!!
    Can you be more specific about what pump you have? The HP does not give the entire story.
    For you size pool, I would recommend at least the 16" bigger is fine and will require cleaning less often. I would NOT recommend zeo sand ... very mixed reviews. Stick with regular pool sand.
    The test kit question is easy: Recommended Test Kits where the TF-100 is the best value.
    Jun 2014
    Douglasville GA
    10
    Hi Jason,
    The pump is about 3 yrs old and says Hayward 1.5HP Flo-LX. It's strange as the new Hayward pump in the catalog now says that a Power flow LX is a 1 hp not a 1.5hp. We got the larger pump as the filter cartridge was larger than required but came with the pool. The cartridge filter was so large and difficult to clean. I'm just ready to try out the sand filters.
    I will order a test kit when I get home tonight.
    Thank you,
    Tina
    38,271
    Usually it is good to have a large cartridge filter because you should not need to clean it as often ... of course that assumes you are maintaining the chemistry correctly and not getting algae. Realize that sand filters tend to be slower at cleaning up a cloudy pool than cartridges. I am wondering if you concerns have more to do with chemistry problems than the filter.
    Depending on the service factor ... the 2 pumps you mention may be identical.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Tina,
    actually, in any case, the biggest filter you can afford will be the best. It reduces time between cleanings and the lower pressure on the larger filter is a good thing.
    Over the long tern (years) you will appreciate the longer time between backwashings.
    dont use the zeo. Use regular pool sand like jblizzle said. Also, there have been some very negative reviews about Quickcrete brand sand. The grains are too small and blow back into the pool.
    Divin Dave,
    Jun 2014
    Douglasville GA
    10
    My cartridge filter still works but a part did break off during last attempts at getting the large filter out to clean it. Now have these weird tiny bubbles all over the pool coming out of the return jet. I thought that I put too much bleach in (just a gallon) but after reading on this site I'm wondering if its a leak? The filter is at least 6 years old and purchased at Rec warehouse.
    38,271
    A leak in the filter would not cause bubbles in the pool. The leak would have to be on the suction side (between the pool and pump) to pull air into the system. Do you see air in the pump?
    Jun 2014
    Douglasville GA
    10
    Jason,
    I'm sorry for sounding dumb but how do you see air in pump?
    I just purchased the recommended test kit and it will hopefully be here by next week.
    Tina
    38,271
    You should be able to see the bubbles through the lid of the pump basket.
    Jun 2014
    Douglasville GA
    10
    Oh, I think there may be a few bubbles there! We took it apart to clean out the basket when we attempted to clean the filter.
    May 2013
    North East Ohio
    959
    Just to make sure - DON'T USE ZEO - USE POOL SAND !!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    38,271
    Did you lube the oring on the pump lid when you put it back together?
    Jun 2014
    Douglasville GA
    10
    Jason,
    No, we didn't. I've got to read more because I feel that I'm messing up things in attempts to clean it. It was so difficult to get apart this season. What do you recommend?
    8,000 gallons. 18' round 52" ht. AG, Hayward flow-XL 1.5hp, original filter cartridge (soon to be sand filter). Ordered TF-100 test kit :)
    golfinglenn's Avatar
    Jul 2013
    Springfield, OR
    96
    An alternative to pool sand is silica sand #20 from lowes, home depot, etc. Much cheaper and works great. I get zero grit in my pool. My pool is a 6600 gal. above ground doughboy and I had to upgrade to this http://www.amazon.com/Hayward-S210T9...=hayward+s210t. It uses 200lbs of sand (about $30 worth). Keeps my pool crystal clear and zero issues so far.
    Glenn
    6500 gal above ground Doughboy with 200lb sand filter and solar panel heater. Converted from Baqua to BBB and never looking back!!
    Jun 2014
    Douglasville GA
    10
    Glenn,
    Thanks for the link on Amazon. I ordered a 18 Hayward pro series sand filter. I also ordered some Magic Lube for the o-ring. Does the filter usually come with connections? I know I will have more questions once the filter and test kit arrives.
    Thank you everyone!
    Any suggestions while I wait on test kit and replacement filter?
    Jul 2013
    Springfield, OR
    96
    It might come with the threaded connectors, but if not that is one thing I would feel comfortable getting at the pool store, or I found mine at home improvement store in the pvc area. Just make sure it is the proper thread (take the top of the sand filter with you) and wrap the threads with about 6 wraps of Teflon tape (also at home improvement store in pvc section). That will help prevent any water from leaking around the threads. They should be 1/5" connectors like these http://www.yourpoolhq.com/hayward-spx1091z4.html.
    38,271
    On fitting that pipe, usually pipe dope (make sure compatible with PVC and ABS) works better than teflon tape and do not over-tighten.
    Jun 2014
    Douglasville GA
    10
    I got my test kit today That was fast shipping! I was wondering if there is a you tube video on doing some parts of the tests. I ordered the recommended test kit TF100.
    38,271
    There are links to videos on the tftestkits website
  20. Back To Top    #20
    Jun 2014
    Douglasville GA
    10
    Hello everyone,
    So far I've completed the Chlorine and pH which are both at the bottom on the test kit. Chlorine 0.5 and pH was at 6.8. The Chlorine was practically non existent but I've been putting in a gallon each day of concentrated bleach.
    Am I doing something wrong with the testing? The new sand filter hasn't arrived yet. The pump is leaking around the drain plug too. Should I continue on with testing all other parts of TF-100 after these test results?
    I also have a weird layer of tiny bubbles on top of pool. Also I can see the bottom of the pool today so I don't understand the low Chlorine level.
    About a 10 to 14 days ago, I added half a bottle of super algacide plus from Dohenys that my neighbor claimed would fix the dark green mess of a pool. Before that the pool was maintained last year by Baqua and variety of chemicals that my partner used. I can't tell you have many filters we went through with that naw is mess.
    The pool is now my responsibility and I'm pretty new with this. I've watched several videos on the test kit last night and will do a few more tests now. The pool/filter and pump is running too. I hope that is fine for the tests. The pool looks like I'm doing laundry with the weird stuff on top of the water, almost like soap suds but tiny bubbles. Occasionally I hear something gurgling like a sucking sound too. Filter is at 12-14psi on a 200 pro-clean waterway cartridge filter.
    Obviously I have a few problems going on here.
    Any help is appreciated.
    I forgot to ask about the CYA/stabilizer. Is this something that I have to buy at a pool store or is it another household item?
