Thread: Intex SWG and plumbing...
    Hi all,
    I have read a few posts on making custom adapters for the Intex SWG -> standard size but a lot of them don't show pics and don't really apply to what I am trying to do. I just replaced my jet(return valve?) and I am trying to connect my intex swg to it. Can someone please tell me what exactly I need to do this? Thanks in advance!
    I did it with some adapters from Home Depot. Don't have the exact names with me but here is a pic. Then I used the hose that came with the pool to finish he connections.
    I had to make my own rubber gaskets as well. I can get more info later.
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Re: Intex SWG and plumbing...
    Thanks for the reply, can't really tell what's going on in the photo so more info would be greatly appreciated as I am sub-novice when it comes to plumbing/pipe-fitting.
    I will try my best. We need to work our way down from 2" to 1" as the 1" has an 1" 1/4" OD to fit the pool hose
    1st piece
    Sch 40 Pvc Reducer Bushing (pvc 02112 4000) by Charlotte Pipe & Foundry http://www.amazon.com/dp/B000H5PWUQ/..._xN3Ntb09E5R7S
    You will need 2 more of these. 1 1/2" to 1 1/4" and then 1 1/4" to 1".
    After you get the the one inch you need a
    NIBCO 436 Series PVC Pipe Fitting, Adapter, Schedule 40, Slip x NPT Male Nibco http://www.amazon.com/dp/B007Q45D2S/..._VR3Ntb005J4AQ
    In this pice you will need to prime and glue a short piece of 1" sch 40 PVC to be able to slide the pool hose on. All of the threaded pieces need Teflon pipe tape. The large 2" adapter is where you will make the gaskets from this
    Silicone Sheet, 70A Durometer, Smooth Finish, No Backing, Red, 1/32" Thickness, 12" Wid... http://www.amazon.com/dp/B000MAMGBY/..._xU3Ntb0HJCZCV
    I made 2 ring gaskets out of this material. All I did was trace the connection from the 2" hose from the SWG and then cut out the middle to make an O ring shape.
    Sorry the links are from amazon but you can get them from Home Depot or lowes. When you get the things pm me if you need any help. Or if you find a better way let me know! But no problems here. Make sure you have a couple of pipe wrenches to put together
